- Joined
- Jan 21, 2010
- Messages
- 25,510
I didn't reply earlier, but these comments may help, or at least may reinforce what you and others have thought...
When you reported that the output voltage rose, the transformer started making a noise etc., this seemed to me as a case of failure in your feedback network.
Without feedback your power supply would go into an over-voltage situation - it is the feedback network that tells it to stop or slow down in order to maintain a regulated output.
The fact that rebuilding the device fixed the issue points to some sort of failure. That may have been as simple as a solder joint that failed, or more complex like a component failure.
Both of these issues need to be addressed in a motorcycle environment. Firstly it is subject to a lit of vibration, so you need a method of construction that is reliable and rugged. Secondly, any component failure issues caused by poor design need to be weeded out or you may find yourself stranded somewhere.
If I were you, I would go back and carefully examine the old board, testing to find out where the feedback signal stops. Alternatively, run the new board for a long time to "soak test" it.
I am concerned that you have replaced fast schottky diodes with far slower diodes for D3 and D4. What does LTSpice tell you will be the negative impact of using fast schottky diodes here?
