12V 200A Synchronous PWM DC Motor Controller
Discussion in 'Sensors and Actuators' started by bbrc679, Jun 22, 2015.
  1. bbrc679
    bbrc679
    5
    Jun 22, 2015
    Can anyone help me fundamentally configure a synchronous PWM DC motor controller? I am trying to reverse engineer a missing component. The first component is a variable 40A PWM that used to be connected to a "box" which I suspect was a fixed PWM. I need to achieve 12V 200A peak for about 30 seconds. (If you must know, it is for a gyrocopter rotor blade pre-rotator...)
  2. Minder
    Minder
    3,076
    657
    Apr 24, 2015
    Do you mean build (configure) a 200amp PWM controller, what is the nature of the motor, 3ph synchronous or DC brushed or BLDC?
    M.
  3. bbrc679
    bbrc679
    5
    Jun 22, 2015
    It is a heavy duty 12V auto starter motor.
  4. Minder
    Minder
    3,076
    657
    Apr 24, 2015
    Is it PM field or wound field?
    Older and larger automotive starter motors are series/wound field and operate in a runaway condition and require a load at all times.
    M.
  5. bbrc679
    bbrc679
    5
    Jun 22, 2015
    I will have to check.
  6. bbrc679
    bbrc679
    5
    Jun 22, 2015
    BLDC. I can find a 200A PWM, but I was curious how linking 2 in synchronous mode works.
  7. Minder
    Minder
    3,076
    657
    Apr 24, 2015
    I would never have expected a starter motor to be BLDC adding the cost for a commutation circuit.
    By synchronous, I assume each to be in syncronism with each other?
    M.
  8. bbrc679
    bbrc679
    5
    Jun 22, 2015
    That is correct.
  9. Minder
    Minder
    3,076
    657
    Apr 24, 2015
    Probabally more details have to be known about any present controller, I would think that essentially you need feed back of some kind on both units, and either have one master and slave or use a μp to synchronize each to a set rpm.
    M.
