120VAC Lamp switched by cmos circuitry?
Discussion in 'Electronic Design' started by [email protected], Apr 12, 2007.
  1. Guest
    Hey guys. I'm a CompE student so my electrical design knowledge
    regretfully doesn't extend far into SAFELY controlling high voltages.
    I have five 120V AC lightbulbs on a lamp and I need to control them
    individually with a computer. I've constructed the lamp, written the
    software, and built the computer interface, but can anyone recommend a
    way to safely control 120V with a 5V DC control line?
    Or can you recommend a fairly inexpensive switch I can buy?
  2. Relays? How much current are you talking about, are these standard bulbs
    (60-100W)? If you need it to be fairly small, then triacs may be the way to
    go.
  3. D from BC
    D from BC Guest
    What's wrong with a relay?
    D from BC
  4. DJ Delorie
    DJ Delorie Guest
    cmos -> transistor -> optoisolator (triac driver, zero crossing) ->
    triac or alternistor
    That's what I use. The key is layout - keep low voltage copper away
    from high voltage copper, use larger trace/space for high voltage,
    plan for insulating the high voltage section to protect the user.
    Use an alternistor if you expect inductive loads.
  5. me
    me Guest
    wrote in @w1g2000hsg.googlegroups.com:
    A relay or a solid state relay. I think Radio Shack (cringe) might still
    sell one that can switch up to 3 amps at 125 VAC...
  6. Donald
    Donald Guest
    Solid State Relay.
    http://dkc3.digikey.com/PDF/T071/P1772.pdf
  7. MooseFET
    MooseFET Guest
    Don't have a "ground plane" going between the two areas.
    Put the low voltage signals on a connector on one end of the PCB.
    Put the high voltage signals on a connector on the far end of the PCB.
    Make sure to pick connectors that can't be partially or fully mated
    wrongly.
    In other words assume an idiot is going to work on it. The idiot may
    even be you one sleepy morning or late night.
  8. LVMarc
    LVMarc Guest
    Go Purdue!
    You need two things:
    A relay made for 120 vac and about a 1KW CONTACTOR rating. P$B T92
    seies for this.
    An interface to go from the PIc I/o pin and to drive the Coil part of
    the T92 contatcor relay. We use this in the backend of a wireless prime
    power actuator switch. Link here..
    http://www.pacificenergyserviceconsulting.com/07ccm4t23.pdf
    Contact me for a breadbaord
    Marc
  9. eh,
    From MOC3010 triac output optocoupler application note:
    http://www.fairchildsemi.com/pf/MO/MOC3010-M.html
    http://www.fairchildsemi.com/ds/MO/MOC3010-M.pdf
    Look at page 5 of the PDF for diagram.
    Been in use here for almost 10 years... (at 230V even :)).
    Switching > 10A with it with an additional thyristor.
  10. jasen
    jasen Guest
    mc3020 and a triac, - google for 3020+datasheet
    Bye.
    Jasen
  11. Eugene Rice
    Eugene Rice Guest
    Crydom solid state relays.
    We used them in the 70s and I'll be damned they still make them and
    Digikey has them in stock.
    They start at US$23 -- not sure if that satisfies your cost criterion.
    Geno
