+120V
Discussion in 'Electronic Basics' started by [email protected], Jun 4, 2006.
  1. Guest
    If a wire is at +120V does it have more electrons or fewer
    than a wire of equal size at ground?
  2. Bob
    Bob Guest
    Read page 243 of your textbook.
  3. Pooh Bear
    Pooh Bear Guest
    The very premise of your question is flawed hence there is no direct answer.
    Graham
  4. Jasen Betts
    Jasen Betts Guest
    assuming no external electrostatic fields.
    If they aaare exactly thhe same size (or better the exact same wire)
    the wire with +120V will have a few fewer electrons.
    120V is not much of a static charge and the deficiency of electrons
    will be relatively small.
    Bye.
    Jasen
  5. Actually to correct you all, a +120v bias to any conductor has no mor
    electrons than the grounded wire at all, no matter what the gauge
    Voltage potential means nothing interms of the amount of electrons i
    a conductor, because iof they are both copper, the electron count i
    the same regardless of charge either way
    Not to be snotty, but the facts present themselves....This is
    popular trick question in electron physics...
    For the rest of you, a static charge can develop at as little a
    0.001pV, and as a whole the assumption of "static
    electricity is wholly misunderstood. Run your fingers through you
    hair and you can generate 50V easily.....You should stud
    "peeling" a bit more when it comes to stati
    charge...lifting a sheet of plastic off a table can generate as muc
    as 1500V..
