P
Peter Bennett
At the risk of wearing out my welcome, I have one more simple question that
I hope y'all might answer.
My main question is on the pin-out of the pot. This is one of those blue,
rectangular pots with a screw on one side for moving the wiper. At first I
connected pin 1 to ground, and the middle pin to the adj pin of the LM317
and to the 240 ohm resistor, as shown in the depiction. But I'm having
problems with pin 3. At first, I hooked it up to the Vout side of the
LM317. It seemed to work just fine, but I grew worried about doing it that
way. So then, I hooked up pin 3 to the positive side of my 9V power source,
and, again, it worked fine. Finally, just out of curiousity, I disconnected
pin 3 altoghether, leaving pin 1 hooked up to ground, and the middle pin
hooked up as described above. To my amazement, everything still worked
fine! What gives?
I finally settled on hooking pin 3 up to the positive side of my 9V power
source, but can anyone explain what the appropriate pin-out is and why?
You should either connect pins 2 and 3 together, or leave pin 3
unconnected.
In this application, you are using the pot as if it was a single
resistor (and, it could be replaced by a single resistor, if you knew
the correct value), so you should treat the pot as a two terminal
device. If you connect pins 2 and 3 together, you provide some
protection against high voltage if the wiper happens to go open
circuit as you adjust the pot - however, your 10K pot is much too high
a value to really help that way.
You may have some difficulty adjusting the pot for such a low voltage,
as you will be right at one end - you probably need less than 100 ohms
to get 1.5 volts, and that is less than 1% of the pot's total
resistance. Better practice would be to use a 100 or 250 ohm pot
instead of the 10K.
