1200 Baud Modem
yeahbuddy
Mar 28, 2012
Mar 28, 2012
Here is a copy of my final project for telecommunications class. Problem is, the old teacher retired and hasnt been replaced and has no current instructor. I wanted to see if I should even attempt such project with my limited knowledge as I do not even know where to begin. So, how would I go about researching and building such a circuit? I do have access to most any commercially available part from school within a reasonable budget.
"The Western Electric 202S and 202T FSK 1200 baud modems use a 1200Hz sine wave (a tone) for logic 1 (mark) and a 2200HZ sine wave (a tone) for a logic 0 (space). Design and fabricate a circuit that will convert a 0.2V peak-to-peak 1200Hz sine wave to -12V DC (RS-232C logic 1) and a 0.2V peak-to peak 2200Hz sine wave to +12V DC (RS-232C logic 0)."
This is all the information given.
(*steve*)
¡sǝpodᴉʇuɐ ǝɥʇ ɹɐǝɥd
25,510
25,510
The naive answer is to use something to detect the frequency, however since there is time for precisely a single cycle during each baud, that's going to be impressively difficult.
Perhaps easier would be to look at the period between zero crossings and return zero if the period exceeds some value, and 1 if it exceeds it.
Alternatively, you could research the techniques used in FSK modems and see if they are applicable to you.
GonzoEngineer
Dec 2, 2011
321
Dec 2, 2011
321
First, google "Modem IC's"
Then look up the data sheet and see how they work.
Easy!
foTONICS
Sep 30, 2011
332
Sep 30, 2011
332
What if you used some sort of low/high pass filter to activate inputs whose outputs manipulated NPN/PNP transistors?
Laplace
Apr 4, 2010
1,252
Apr 4, 2010
1,252
Have a look at Cypress AN-2336 "Simplified FSK Detection" which describes demodulation using signal correlation. Seems pretty interesting, and is rather simple to implement.
N2336 - PSoC® 1 - Simplified FSK Detection http://www.cypress.com/?rID=2735
