120 VAC contactor.
Discussion in 'Electronic Equipment' started by Rich.Andrews, Aug 11, 2004.
  1. Rich.Andrews
    Rich.Andrews Guest
    I am looking for a contactor or relay that has the following characteristics:
    1) silent or nearly silent in operation.
    2) Be able to handle 20 amps of current.
    3) be available in a variety of coil voltages including 120VAC.
    4) Cost no more than $30.00 each
    5) Rated for continuous duty use.
    6) Operable in any position.
    Does anyone have any suggestions?
    r
  2. RWatson767
    RWatson767 Guest
    120 VAC contactor.
    Ebay
  3. As I understand it, contactors are used for loads like motors that draw high
    starting currents, or that have inductive kickback when turned off. That
    is, loads that are hard on "normal" relay or switch contacts.
    What is your load? Do you actually need that level of protection? If not,
    then you might be well satisfied by solid state relays (SSRs). Many
    available in that price range.
