E
eman
I work for a commercial electrical contractor and we have several
property management companies as regular customers.
We are required to replace main circuit breakers or test blocks in
services on a fairly regular basis. Most of the time, it appears that
the main circuit breaker or test block was burned up due to alum.
wiring installed from the test blocks to main c/b then from load side
of main c/b to panel.
We of course replace all wiring with copper and replace test bllock or
main c/b as required.
The question I have is it appears that most of the problems appear to
occur on 120-120 delta services. The high leg is usually the burned
(or most burned in some cases) leg.
On a high leg system, there is usaully a smaller load on the high leg
(Atleast in the case of these smaller tenant spaces where there is
limited 3-phase or 1-phase 240V equipment). This would lead me to
reason that one of the other legs would burn up due to load imbalance
more frequently that the high leg.
Is it just coincidence, or is there a reason why the high leg would
cause such a problem?
Thank you,
Eric
Thank you,
Eric
