D
Dr. Slick
Good Evening,
I'm building a 12 volt recharging system with
a 12 volt, 0.375A (12"x12") solar cell, and this charge
controller:
http://store.dependablesolarproducts.com/etaen12vo5am.html
The battery is a 12 volt NiMH, 3AH.
I would also like to be able to use a hank-cranked
dynamo charger, and also a way to recharge the battery
using regular 120 AC mains. The dynamo that i wish to
use comes from a very cheap survival radio, that uses
3.6 volt NiMH, but i think there are Zener diodes that
limit the voltage coming from the generator to 7-8
volts, so i think i can remove these to get more
voltage (closer to 13-14 volts?).
I believe i could just use a regular 13.8 volt
DC power supply, and have a 3-way switch to go from
the solar cell, to the dynamo, or to the AC power
supply, directly to the charge controller above.
I other words, the charge controller (made for
photovoltaics) would be used for any of the three
sources of DC power.
Does this sound like a good idea? Or should
i get a separate charger for the DC power supply?
Is there a cheap, simple LED circuit that can
indicate the charging function and the state of the
battery?
Thanks for your help,
Slick
controller:
battery?
Slick
