12 V Power
Discussion in 'General Electronics Discussion' started by machineman, Oct 7, 2012.
  1. machineman
    machineman
    3
    Oct 7, 2012
    I have a digital video recorder that currently uses a 110 V AC power supply that outputs 12 volts DC @ 3 amps. I would like to power this device from a 12 V car battery. Can this be done ? If so, how, and how long can I expect it to operate under the battery power?
  2. duke37
    duke37
    5,364
    771
    Jan 9, 2011
    If you have a battery with a capacity of 10Ahr and you draw 3A then the time is about 3 hours.
    If you are drawing 2A and have a 40Ahr battery, then the time is 20 hours.
  3. machineman
    machineman
    3
    Oct 7, 2012
    Thank you very much. That is very helpful. I certainly appreciate it. Do I need to regulate the incoming power ?
  4. davenn
    davenn Moderator
    13,808
    1,943
    that really depends on how much variation the DVR can tolerate from the 12V
    A fully charged battery could be as high as 13.5 - 14V
    Is the currently used plugpack supply regulated ?
    it should be marked regulated or unregulated
  5. machineman
    machineman
    3
    Oct 7, 2012
    Dave,
    I will check that. Thank you.
