Dinesh Dangi
- May 10, 2018
- 4
- Joined
- May 10, 2018
- Messages
- 4
Parameters:- 3 phase 115/200 volts AC Input, Input Current at full load is 18 Amps per phase at the 200-amp output, Input Frequency is 380 to 420 Hz, DC output is 28 volts (Nominal) Current is 200 amps, Output ripple is 1.5-volt maximum Question : on transformer secondary side it is star and delta connection with rectifiers (check the link: 12 pulse rectifier). In this transformer, secondary first is 12.5 volt and second secondary voltage is 21.6 volt approx. which is line to line is 21.6 and phase to phase is 12.5 in star connection.for all transformers it is like this. Now my question is I want to know the output voltage of the rectifier circuit. can someone explain me the working of 12 pulse and also how to calculate output voltage. 2nd question: the filter circuit which you can see in the image is what type of circuit? you can see the value of capacitors like c5 is 4uf, c4 800uf, c6 40uf, c7 0.22uf AND c1, c2, c3 is 2uf, L is 8uH, and resistance is 60 ohm. how this capacitor value calculated? and also what is the use of c1,c2,c3? Thank you in advance. please explain if you know anything about the circuit. Note: B1 is the Fan for cooling.
