110VAC hair clipper on 220VAC help please
Discussion in 'Troubleshooting and Repair' started by Sebas, Oct 1, 2017.
  1. Sebas
    Sebas
    Oct 1, 2017
    are there risks to using a 110v 60hz hair clipper from the U.S in Europe. I think the power supply here is 220v 50hz
  2. Minder
    Minder
    3,182
    690
    Apr 24, 2015
    For a hair clipper you should be able to get a small adapter for 230v down to 120v.
    M.
  3. FuZZ1L0G1C
    FuZZ1L0G1C
    366
    118
    Mar 25, 2014
    If you can't find this adapter at a hardware store, I bought mine at a travel agency (220V>110V 3.5A).
    The output of mine uses two flat pins (for a 110V fax machine).
    Of course, you must check that output pins are compatible with your clipper.
    The 60>50Hz frequency drop won't make much difference.
    You'll just cut hair 17% slower. ;)
  4. Alec_t
    Alec_t
    3,058
    834
    Jul 7, 2015
    If the clipper is of the mechanical resonance type the frequency is important. 50Hz may not work.
