I am looking for an output transformer that will do 10KHz to 55KHz
with a reasonable degree of linearity of the entire range.
Is this possible? If so, what type and construction should I be
looking at.
Ketih Greiner
Hello Kieth,
Whether this is simple depends on some other specifications. I am
thinking of power (voltage and current) to be transferred, isolation
voltage and capacitance (between windings), DC current through
windings, etc..
When the isolation is functional only (so no electrical safety is
involved), and requirements with capacitance are not that stringent,
it can be easily done up to several hundreds VA. However when there
must be very low capacitance or (for example) 3500V double insulation
safety requirement, it will be more difficult to keep low both linear
and non-linear distortion.
Maybe you can provide us some more information.
Best regards,
Wim
PA3DJS
www.tetech.nl
