100Mhz Data Acquisition
Discussion in 'Electronic Basics' started by [email protected], Apr 28, 2006.
  1. Guest
    We are seeking a compact/low-power Data Acquisition device for
    deployment in small sub ocean devices. We need to sample 10Mhz pulses
    at better than 10 samples per pulse (e.g. ~ 100Mhz). The pulses arrive
    at around 10mV.
    At the moment we are using a rather large and cumbersome National
    Instruments device. This works fairly well but is not compact or low
    power (>30watts would be nice)
    Does anyone have experience with a DAQ device that might meet our
    specs. I am emailing a few vendors at this time as well
    Fritz
  2. Phil Allison
    Phil Allison Guest
    ** Despite the implausibility of this post it arrives from the :
    Woods Hole Oceanographic Institution
    OrgID: WHOI
    Address: 266 Woods Hole Road
    City: Woods Hole
    StateProv: MA
    PostalCode: 02543
    Country: US
    ** What the heck generates 10MHz pulses under water ??
    Dolphins using CB ???
    ......... Phil
  3. Phil Allison
    Phil Allison Guest
    "Phil Allison"
    ** This is our OP - complete with cute pic:
    Frederick N. Sonnichsen
    http://www.whoi.edu/scitechdir/staff.go?id=355
    He works for:
    Serious stuff .......
    ........ Phil
  4. Guest
    VHF Tunicates?
    Naaaaaahhhh- seriously we are modulating a 10Mbs
    ethernet transmitter using bright LEDs. I want to do some DSP and noise
    analysis. We are using a nice "neutrino detector" PMT the size of a
    basketball for a receiver.
    We will deply below the ocean photosphere, beyond 1000 meters where it
    is very dark. Typically we lilke to can up things in a Ti cylinder and
    operate from batteries. Compactness, Power consumption, and Thermal
    output are everything to us in Oceanography.
    Cheers,
    Fritz
  5. Phil Allison
    Phil Allison Guest
    ** You are on the WRONG newsgroup - Fritz.
    There is nothing BASIC about your activity or question.
    Try posting on " sci.electronics.design " instead.
    .......... Phil
  6. Joerg
    Joerg Guest
    Hello Fritz,
    If you intend to do a circuit board look at the TI converter ADS5500.
    14bits at 125MHz. That, plus a nice gain controlled preamp such as an
    AD603 (Analog Devices) might be the ticket and it will be a lot lower in
    power consumption than 30W.
    Regards, Joerg
  7. Guest
    OK and thanks Joerg. I looked at the sheets for the ADS5500 -looks like
    a good low power option-Also I really like the fact that they have an
    eval board. The price is reasonable so I'll check it out-
    Per Phil's comment I'll post in the "design" board next time-tough to
    know where 'basic" begins and ends these days with all the technology
    out there, especially for a guy that started on vacuum tubes
    Cheers All and Thanks,
    Fritz
