100MHz clock Oscillator CFPS-73 test circuit
Discussion in 'General Electronics Discussion' started by azher_bashir, Feb 2, 2012.
  1. azher_bashir
    azher_bashir
    Jan 25, 2012
    Asalam O ALikum,
    I am working on 100MHz clock Oscillator CFPS-73 test circuit according to data sheet. After PCB designing of test circuit When i apply voltage souce, the oscilator was not draging any current. It menaz that its not working?Can any 1 suggest that is there any probelm in circuit or any other reason.....
    Here is the link of data sheet inclusive of test circuit.
    http://www.iqdfrequencyproducts.com/products/details/cfps-73-12-01.pdf
  2. Resqueline
    Resqueline
    2,848
    Jul 31, 2009
    Most likely there is an error (a mistake) in the PCB layout (design).
  3. Rleo6965
    Rleo6965
    585
    9
    Jan 22, 2012
    Double check etch of pcb if connection was on correct pins of Clock Oscillator and broken connection.
  4. davenn
    davenn Moderator
    13,558
    1,854
    hi welcome to the forums :)
    the current drain is very small ~ 20mA, how were you measuring the current drain?
    did you have a frequency counter on the output to actually see if there was a signal being produced ?
  5. vinit2100
    vinit2100
    100
    Oct 21, 2013
    1.First check the schematic symbol of your oscillator and cross check the pin number.
    2. Pin number 1 (PAD 1) should be either connected to VCC or left unconnected.
