Jamie Morken
I was initially thinking of designing a 100kHz SMPS with using 200kHz
ADC feedback of the output voltage and current fed into a DSP which
would directly interface to the fet drivers, and using cycle by cycle
regulation based on these readings, but I think this may be very
difficult to read these signals cleanly without them being noisy
from all of the switching noise. So as an alternative I am thinking
that it would be better to use a SMPS controller IC with voltage and
current feeback inputs, which seem to be easier to get to work than a
200kHz ADC in this environment and use its output PWM signal as an
input into a DSP or CPLD/FPGA for controlling the primary side
fullbridge to drive the transformer. This reduces the flexibility of
the power supply as the current and voltage limits are set in hardware
rather than software, unless some DAC/comparator etc setup is used to
drive the SMPS controller IC feedback, but it is easier to trust a
SMPS controller IC rather than a complex ADC/DSP software system to
control a power supply. Perhaps a tradeoff would be a controller IC
with a digital interface to allow on the fly adjustment of the
voltage and current limits as well as the PWM frequency etc. Does an
IC like this exist? I think it would be pretty useful! Any people
here ever use high speed ADC and software to control an SMPS?
cheers,
Jamie
cheers,
Jamie
