James Arthur
In practice, +30v and two cascaded zener shunt regulators did pretty
well, but you could also do something like this:
(view in Courier font).-----------------------------.
| | R1 |
| | (trim for |\ |
'-' desired iz) | \ |
| | \-------o-------> Vout
/ \ ZD1 | | / |
| | |/ | | R2 (trim for
| | | | desired Vout)
GND | |
| |R3
GNDI think the above circuit's even self-starting if you choose an op-amp
with sufficiently high bias currents and use low-enough valued
feedback resistors. Otherwise, throw on a starter.Cheers,
James Arthur
741 (and some brands of 709) OpAmp's will self-start in this
configuration. I built hybrid circuits using this circuit between
1970 and 1973 at Dickson Electronics. Other OpAmp's may NOT
necessarily self-start. So I handled that problem with a
resistor/disconnect-diode scheme.
...Jim Thompson
Well, I was thinking of the LM324, what with its PNP inputs, not to
mention fabulous precision & noise ;-), but there are others...
Oh, sheesh ... okay, you've shamed me into it:
"Bootstrapped reference with startup"
Vcc
| |R4 | | R1 |
| | | | (trim for |\ |
'-' '-' desired iz) | \ |
| D1 | | \ |
V1-> +--|>|--o----------------|+ \ |
[*] | | | \-------o-------> Vout
| |R5 ,---' .--------|- / |
| | / \ ZD1 | | / |
'-' | | |/ | | R2 (trim for
| | | | | desired Vout)
GND GND | |
[*] V1 < V(ZD1) | |R3
GND
Cheers,
James Arthur
