R
rob
Hi
I am a total novice in electrics and am not sure were to post this
question?.. i hope some one can help me...I need a transformer that
can supply aprrox 6 Volts Dc at 75 amps..
I have just purchased a 240 v ac input 1 KVA rated transformer its AC
output is 6v ,8v and 12 V..Now i understand that i need to rectify
the current and have just got off ebay a dozen MBRP40030CTL 400A 30V
schottky diodes with low Vf.. i assume that these will be able to
supply a 75 amp current.. at 6 v?..I got them because there rated at
400 amps..and were very cheap!
http://www.onsemi.com/pub/Collateral/MBRP40030CTL-D.PDF
My other question is that there is label on side of the transformer
which is hand written saying that it is rated at 83 amps?..
Label pic
http://www.saspyro.pwp.blueyonder.co.uk/label.JPG
yet when i looked inside i found a large fuse holder with 63 amps at
550v printed on it.?
http://www.saspyro.pwp.blueyonder.co.uk/fuse.JPG
yet the fuse thats attached to it says 40 amps at 550VAC..
http://www.saspyro.pwp.blueyonder.co.uk/Fuse2
Now i am confused ? if the fuse is 40 amps does that mean i have only
transformer that can supply 40 max?..
Inside the transformer there is a board with 1KVA printed on it
http://www.saspyro.pwp.blueyonder.co.uk/inside.JPG
i hope this makes some sense?
Is there any way i can test to see if it can supply 75amps ?
Rob
Label pic
Rob
