Jean-Pierre Coulon
I am making a simple lowpass LC filter at 6 MHz in a 50-ohm system with
passive elements. I've made the inductor (L=4uH) by winding copper wire around
a 1-Mohm, 2W carbon resistor. Since I want Q = 1 or so I don't care about the
loss angle of the resistor material.
But when I compare the phases of the input and output signals with a passive
phase detector (diode-mixer like) and a spectrum analyzer above 5 KHz the
noise floor is consistant with that of an attenuator in a 50-ohm system, but
below, the noise spectrum climbs in 1/f.
Could the material of my resistor-based cylindrical core explain this?
Are other materials better than a big resistor at 6 MHz?
Regards,
Jean-Pierre Coulon (here "cacas.pam" is what others call "nospam")
Regards,
