0V reference
F
Fred Bear
Can anyone help with designing a 0V reference?
FB
F
Fred Bear
Thanks for the reply, Rene.
100% accuracy, 0% drift - It is critical that this is a 0.0000V reference.
FB
F
Fred Bear
I was told that a resistor to ground would do it, with a capacitor to 0V to
stabilise the voltage. What values of resistor and capacitor would you
recommend for 1 amp?
Fred
S
Slurp
Fred
For your quoted 0.0000V reference at 1A the resistor needs to be <100 micro
ohms. -- but is in conflict with your required 100% accuracy.
Ideally you need a 1 * 10 ^(-(infinity -1)) femto ohm resistor and an
(infinity - 1) Farad capacitor.
BTW - Do you know what the capacitance is between two pinheads 1 light year
apart?
Slurp
S
Spehro Pefhany
FB
0.0000V is trivial. 0.0000000 is more difficult.
Best regards,
Spehro Pefhany
Joerg
Hello Spehro,
Nah, replace the bolts with marine grade stainless and give it some more
torque :)
Regards, Joerg
R
Robert Obermayer
torque :)
Nah, stainless is a bad conductor, worse then steel.
Copper is what you need ;)
If its a audio application, you will need a 101%
super-duper-ultra-OFC-OMG-WTCF-STFU plated bolt made from 50 year old
5-times refined silver from a certain mine in england that was processed
by a tibetian monk.Othwerise it will sound rough, cold, shady and dark.
Joerg said:
Hello Spehro,
torque :)
Even marine-grade stainless steel is stainless by virtue of a thin and
cohernet layer of chromium oxide - I don't know which one - which has
an appreciable electrical resistance.
My conductivity meter stopped using stainless steel electrodes - a bad
idea that I'd inherited - at the point where I could prove that the
oxide film had an appreciable electrical resistance by changing that
resistance by exposing the film to 2% aqueous sodium hydroxide (whose
conductivity the meter had to monitor, along with that of the tap water
that washed it away).
S
Spehro Pefhany
Hello Spehro,
torque :)
Lots of unpleasant ways for 100nV to crop up..
Best regards,
Spehro Pefhany
M
Michael A. Terrell
You left out "Dank" ;-)
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
Joerg
Well, guys, this was meant as a joke...
Ok then, how 'bout a nice thick gold plating on everything? Of course
only gold mined from a particular mine here in California in 1850.
Regards, Joerg
R
Rene Tschaggelar
A reference has never 1 amp. References just
supply the voltage, not power. Lookup
"supply" or "voltage regulator"
Rene
S
Spehro Pefhany
How pure? Gold-copper doesn't have much thermocouple voltage, but a
couple tenths of a degree C would be enough to swamp 100nV. Galvanic
action might be possible too.
Of course the advantage of selling such a 'reference' to
unsophisticated customers would be that few would be able to test it
sufficiently accurately to complain.
Best regards,
Spehro Pefhany
P
Pooh Bear
In that case the reference has appreciable resistance / impedance.
An ideal reference would have zero impedance and laugh at an Amp.
Graham
P
Pooh Bear
You've been looking at some schematics that have 0Vref on them haven't you ? (
blushes )
Graham
R
Rene Tschaggelar
An ideal reference yes, but actual references
only supply a few mA at close to zero ohms
Rene
