C
cm
Could someone tell how much amperage you would get using 700' of 0
copper wire from a 240V 200 amp service?
curt
curt
Do you mean that until I apply a load , there's no way to determine how
much load it will handle?
hungry1 said:Do you mean that until I apply a load , there's no way to determine how
For example, if you've got 700' of wire, (350' out and 350' back, say)
since #0 AWG soft-drawn copper wire has a resistance of about 0.1 ohms
per 1000 feet, that'll be a resistance of 0.07 ohms.
Now, if what you've got on the end of the cable wants to see
240V ±10%, then the most the cable can drop is 24V, and since I = E/R,
the most current you can put through it will be 240V/0.07R ~ 3429
amps.
BUT... with 3429 amps flowing through the cable it'll be dissipating
P = I*E = 3429A * 24V = 82,296 watts, so that's about 118 watts per
foot. That cable's going to get HOT, and when it does its resistance
is going to increase, which will further reduce the voltage across,
and the current through, the load.
Perhaps a nitpick, but I think you shifted from a 24 volt drop to
dropping the entire 240 volts across the wire resistance.
hungry1 said:Maybe I need to give more details and revise my question.
What size wire would one need to run service to 10 homes in a distance of
700'???
hungry1 said:Sorry if I offended anyone, with my questions, I am trying to help people
get electric to their homes in my area with a generator that outputs
200amps.We can get single 0 copper wire where we are. but the information
that I need is NOT available to my knowledge.
