0-5V to -24-24V using an opamp?
Discussion in 'General Electronics Discussion' started by JawadWalker, Jul 29, 2017.
  1. JawadWalker
    JawadWalker
    13
    Feb 6, 2016
    Hi, I'm trying to scale a 0-5 volt signal to a -24-24 volt signal (0V to -24V, 2V to -4.8V, 4V to 14.4V, 5V to 24V, etc.). I made this circuit with the equations from http://www.stefanv.com/calculators/hp67_offset_gain.html and it works, but will it work in real life?
    It says on that page that "Theoretically, the formulae presented here work perfectly well for gains between -1 and 1 (i.e. |m| < 1). However, many real-world op-amps are unstable in such cases. Instead, it will usually be necessary to design for a higher gain (|m| ≥ 1), with an attenuator on the input side.".
    How would I make an attenuator if I need one? Thank you.
    [​IMG]
  2. (*steve*)
    25,418
    2,788
    Aside from the fact that this is a very high voltage power supply voltage for an op-amp, your calculations are essentially correct.
    I guess you could make a high voltage op-amp from discrete components, or add a high voltage output stage to a normal op-amp.
    The next issue is that you have chosen some quite bizarre value resistors . Consider that for normal resistors you can't get exact values like the ones you have chosen. Would 120 ohms, 2700 ohms, and maybe 270 ohms be close enough?
  3. JawadWalker
    JawadWalker
    13
    Feb 6, 2016
    OPA445 is a high enough voltage op amp right? And yeah I've fixed the resistor values to use ones in parallel. So the output will be pretty linear to the input right?
  4. (*steve*)
    25,418
    2,788
    R3 and R4 are unnecessary. Just calculate R1 and R2 for a gain of 24/5.
  5. JawadWalker
    JawadWalker
    13
    Feb 6, 2016
    How will I offset it then?
  6. (*steve*)
    25,418
    2,788
    You're right. The second time I looked at this I assumed the voltage source on the left was your input, sorry.
