0-5V adjustable voltage regulators?
Discussion in 'Electronic Design' started by [email protected], Jun 27, 2007.
  1. Guest
    Anyone know of an adjustable voltage regulator that:
    -outputs 0-5V (or 1-5V)
    -can source 100mA over that range
    -is powered by 6V
    Thanks.
    KCJ
  2. D from BC
    D from BC Guest
    A low drop out type might be needed.
    ~1V to 5V adjustment more probable due to internal references
    typically around 1V to 1.5V.
    As an example:
    http://www.fairchildsemi.com/ds/FA/FAN1117A.pdf
    It's not great but all I can think of for now..
    D from BC
  3. ehsjr
    ehsjr Guest
    A dc-dc converter chip like the TI MC33063 and a few external
    components will do it, except the minimum is 1.25 volts.
    http://focus.ti.com/lit/ds/symlink/mc33063a.pdf
    Since your current requirement is low, you can use a
    trick to get down below 1 volt:
    Vin--[Regulator]Vout---+
    | [Load]
    | [D1]
    | [D2]
    Gnd ------+------------+
    or
    | [Load]
    [D1]
    [D2]
    Gnd ------+
    If you short out D1 and D2 when Vout needed
    is above 1.25, you get better regulation.
    Note that [Regulator] above is used to
    represent the complete regulator circuit
    and its associated components - the drawings
    are intended to show only the addition of the
    two diodes, not the complete circuit.
    Ed
  4. whit3rd
    whit3rd Guest
    Most 'adjustable regulators' use a resistor divider on the
    output and compare to a fixed (1.2V typically) reference, so
    they only go to 1.2V minimum. Three-terminal and four-terminal
    regulators are ruled out.
    The LM10 op amp includes a voltage reference, and can get close
    enough to the rails to do what you want, except the 100 mA
    part. Can you settle for 20 mA?
    Add a pass transistor to the LM10 and it's easy.
