John Devereux
Raveninghorde said:As far as I can see that doesn't work if the output is shorted.
No, although the output will indicate some high full scale value I
think.
You did say it was around 16V...
If it really has to work 0-16V, and you also need 1mV precision, then
there is not getting away from the big bucks resistor.
Or does the 16V supply collapse too when it is shorted? Like you are
measuring current using a high side resistor on the output side of a
current limited regulator?
Battery charger?
You could look at the "flying capacitor" circuit as found in that linear
app note.
