Spehro Pefhany said:
I didn't see much information on details of construction in the thin
R&K book.
There's a lot more detail in B. Hague/TR Foord's excellent book on
bridge methods (and even more in the copious references), enough to
lead me to think I might not be able to make a 1ppb/K transformer the
first time or second time.
Here's my (commercial) one.
http://www.tegam.com/product.asp?modelNumber=PRT-73&redirected=1
At 30lbs and >$12K new it's not very practical as a component.
Apparently. And that one is not by an unknown name. McGregor et al. at
NBS found they had to ovenize the ratio transformer (they were
shooting for a few ppb total error).
Certainly could be, and perhaps silly and/or obvious.
Any other ideas for getting a DC ratio stable to within, say, 10ppb/K,
and WITHOUT ovenizing?
We had a nice thread "SMD TC" about precision PWM (and precision
resistors) last year.
https://groups.google.com/forum/#!s...i.electronics.design/eHx0O3vg0t4/zBynI1Mht7AJ>
In particular James Arthur came up with a nice scheme to cancel supply
ripple effects which would otherwise create errors, reproduced below in
full.
Of course I don't know if this will get to 10ppb but I would think some
PWM scheme would be the way forward. I think flukes calibrators use PWM
and do approach this level.
(James' original post follows)
OK, after six months, six or seven days most weeks (and, due to
committing to a not-so-clearly defined project, mostly for free), I've
just gotten my gadget in shipping-shape.
So, time to play!
Here's the basic PWM:
Vref >----/\/\/-----O :
R1 \ : R3
\ : 1M
O-----/\/\/---+-----> Vout
R2 : --- Cf
0 >----/\/\/-----O : ---
Fig. 1
To me, 16 bits on the cheap is plenty cool. But if the bar is doing
something extraordinary, like 1ppm, then it seems fair to use fancier
parts.
So, let's assume an FPGA and 100MHz clock rate, driving the switch.
The switch can either be the FPGA output, or an extra gate (or
paralleled gates).
We can get 1ppm modulating 100Hz in 10nS chunks. Or 40Hz in 25nS
chunks, etc. Whatever works out with our switch-speed.
Switch mis-match (R1-R2) produces a code-related error, maximized at
mid-scale. With R3=1M, my algebra says <0.5ppm non-linearity from
switch mis-match requires |R1-R2| <= 1 ohm. Y(A)MV.
Paralled gates, analog switches, or a BSS138 buffer stage could do
that. I measured (characterized) some 74ACxx parts a ways back for
this.
Another, liberating possibility is to bootstrap the switches,
canceling most of their effective resistance:
Vcomp >-------------.
: | | R4
Vref >----/\/\/-----O : | |
R1 \ : '-'
\ : | R3
O----+--/\/\/---+-----> Vout
R2 : --- Cf
Fig. 2
If Vcomp is such that i(R4) = i(R3), the voltage drops (errors) across
R1 and R2 disappear. This next version does that.
C1
Vpwm >-----+----||----.
_| |__| |_ =2Vrefp-p| |
.....................V... | | R4
: . : | | 100K, 1%
Vref >----/\/\/-----O . : '-'
R1 : \ : | R3
: \ : | 100K, 1%
: O---------+---/\/\/---+-----> Vout
R2 : : --- Cf
0V >----/\/\/-----O : R4=R3 ---
Fig. 3
C1-R4 re-create the same currents as flow in R3. Effective switch
resistance (R1, R2) is lowered by about two orders of magnitude,
allowing us to reduce R3 and lower the output impedance.
Filtering the 100Hz PWM to 1ppm takes 14 time-constants = 140mS.
So, Fig. 3 is a working solution. It's linear and accurate, but needs
a hi-z buffer amp and it's slow. A 16-bit version could be faster,
with lower-z output. Or, splitting the DAC up into two sections
improves both those properties too.
C1
Vpwm(hi) >------------+---||---.
.....................V... .-.
: . : | | R4
Vref >----/\/\/-----O . : | |
R1 : \ : '-'
: \ : | R3, 0.05%
: O-------+--/\/\/---+---/\/\/--+-----> Vout
: : | Rf |
R2 : : | --- Cf
0V >----/\/\/-----O : R4=R3 | ---
Vpwm(lo) >------------. |
: . : | | R7
Vref >----/\/\/-----O . : | | = 1000 x R3, 0.05%
R5 : \ : '-'
: O------------------'
R6 : :
Fig. 4
If the upper and lower DACS cover 1,000:1 each, we could lower the
clock frequency to, say, 10MHz, pump it with a uC, and still have a
10kHz composite waveform that one-pole-filters to 1ppm in 14 * 100uS =
1.4mS.
The R7-R3 ratio is critical to absolute accuracy and monotonicity.
The top DAC divides Vref accurately into 1,000 parts, so a 1% error in
the R7-R3 divider ratio represents an error of 1 part in 100 of
1/1,000th, or 1 part in 100,000 overall. 0.05% ensures 0.5ppm.
Likewise, to ensure monotonicity to 1ppm, the lower DAC's contribution
of 1,000 lsb's cannot be off by >1 part (lsb) in those 1,000 lsb's, or
0.1%
The low DAC represents a small, code-related d.c. load on R1, R2 via
R7. That needs to be either kept small, or compensated.
Back to the topic of this thread, the effect of T/C errors in the
divider resistors is reduced by the divider ratio, a factor of 1,000.
So, there's a stable, accurate, 1ppm PWM DAC made with non-critical
parts.
Cheers,
James Arthur
(end quote)
