† Any suppliers of LCD glass pins?
Discussion in 'Electronic Components' started by William E Miller, Mar 25, 2007.
  1. I'm looking to find one or more specific suppliers of the pins used to
    connect to glass LCD panels so they can then be connected to a ribbon,
    board, etc.
    I'm talking about the ones that look like this:
    http://www.pacificdisplay.com/images/intfig1.gif
    Here's a crude drawing, too:
    _______ ______________________//
    / PIN | | LCD
    | | PANEL
    | _____|
  2. Guest
    Silly question maybe, but do you have the fixtures and adhesives to
    mount these properly? Normally you order the LCD with the pins
    preinstalled if you want it.
  3. This would be for retrofit or modification - occasional use, really.
  4. Guest
    Go to <http://www.mill-max.com/>. In "Quick Find by Description"
    select "Printed Circuit Pins". On the results page select "Edge-Mount
    Pin". A part similar to what you want appears to be a series 7310 Edge-
    Mount Pin.
    This type of pin is not infrequently used for making SOIC-to-DIP
    adapter boards.
    I suspect that the purpose-built pins you see on LCDs are custom
    manufactured for the LCD vendor based on their selected glass
    thickness.
