µPC-1213C
Jiri Placek
Does anyone please have datasheet for NEC µPC-1213C or NTE 1615? Ir
is a DIP-8, 2.4 W audio amplifier IC used without any cooling fin in
SONY ICF-6500W shortwave portable receiver. The chip is apparently
overloaded since it frequently fails in this radio. My options are
either to buy a replacement at Mouser or to install another IC with
more power. To find an acceptable more powerful IC I need a data
sheet for the original one. The web search failed to locate any data.
Any lead is greatly appreciated.
Jiri Placek
Boyertown, PA
F
Franc Zabkar
I think you mean NTE1516.
I don't have a datasheet, but the pinouts are:
1 input
2 NC
3 filter
4 Vcc
5 feedback
6 output
7 bypass
8 feedback
Tab is ground.
Rating - 1.8W, Vcc = 11V max
- Franc Zabkar
S
Syl's Old Radioz
"Robert Mozeleski" a écrit dans le message
Opps, are you sure it's not NTE1516? That one is coming up as a dip 8
audio amp.
I think you're right. I double checked using an ECG catalog from1998
and it is indeed an 8 pins dip rated at 1.8W, no cooling tab?
It is also discontinued in the 1998 catalog...Oh..Oh...
Syl
jtaylor
more power.
Or glue some fins on it.
