Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electronic Repair > Zenith Z56Z95 RPTV picture is red
Reply
Thread Tools Display Modes
Chris
Guest
Posts: n/a
      10-11-2005, 01:21 AM
I sold my TV to my neighbor a month or so ago & the picture was fine,
but I was over & now the pic has a reddish cast to it.
I'll get it fixed eventually (the tank of the toilet on my second
floor cracked & flooded all 3 floors), but I was wondering about what
cost I'm looking at & what could possibly be wrong. Any advice would
be appreciated.
hrhofmann@att.net
Guest
Posts: n/a
      10-11-2005, 01:28 AM
Did the flood affect the TV or was that just non-information you
provided about the toilet??
H. R. Hofmann
Chris
Guest
Posts: n/a
      10-11-2005, 02:15 AM
>H. R. Hofmann
Sorry, just needless info about why I have to wait to fix it.
hrhofmann@att.net
Guest
Posts: n/a
      10-11-2005, 01:07 PM
Find the red screen control and try turning it down a bit, That should
remove the reddish cast. Then, the questions is is the set stable, or
does it continue tio get red with time. You can fix the other stuff
while you are waiting to see if turning the red screen down is
permanent or not.
Bob Hofmann
Chris
Guest
Posts: n/a
      10-12-2005, 01:01 AM
>permanent or not.
>Bob Hofmann
Thanks. What do you mean by red screen control? Is this in the
service menu or something on a circuit board? I'm not a tech, but I
can get into the service menu.
Could it be not too much red, but maybe too little of another colour?
The menus appear greenish when they should be yellow. I'm not sure
what colours would make up yellow.
Chris
Asimov
Guest
Posts: n/a
      10-12-2005, 04:11 PM
"Chris" bravely wrote to "All" (11 Oct 05 21:01:24)
--- on the heady topic of "Re: Zenith Z56Z95 RPTV picture is red"
Ch> From: Chris <(E-Mail Removed)>
Ch> Xref: core-easynews sci.electronics.repair:344852
>permanent or not.
>Bob Hofmann
Ch> Thanks. What do you mean by red screen control? Is this in the
Ch> service menu or something on a circuit board? I'm not a tech, but I
Ch> can get into the service menu.
Ch> Could it be not too much red, but maybe too little of another colour?
Ch> The menus appear greenish when they should be yellow. I'm not sure
Ch> what colours would make up yellow.
Ch> Chris
Green and red makes yellow on a CRT. If what should be yellow is
greenish means it lacks red. On nearly saturated colours it means the
red drive is insufficient. However, the red cast symptom means the red
threshold or bias voltage is off. The 2 symptoms might be related, for
example if the red driver is faulty. Then the red bias is upset and
the red drive or gain might be too low, both together. But it might be
something completely different like a shorted red gun.
A*s*i*m*o*v
.... You may be a tech if you're entertained by a 6-pack and sparking HV.
dmwargo
Guest
Posts: n/a
      10-14-2005, 03:26 PM
Find a dumpster and throw it in. A bad CRT (picture tube) is very likely in
these things. Sorry.
"Asimov" <Asimov@-removethis-bbs.juxtaposition.dynip.com> wrote in message
news:MSGID_1=3a167=(E-Mail Removed)...
> >permanent or not.
> >Bob Hofmann
> Ch> Chris
> A*s*i*m*o*v
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Mitsubishi VS6015R RPTV no sound or picture; tubes have HV BFriedl Electronic Repair 4 01-16-2007 12:22 AM
No Picture on Zenith rz56z83 projection tv linky835 Electronic Repair 4 12-11-2005 05:14 PM
Sony RPTV KP-46V15, powers on, but no picture or sound............ MrAndy Electronic Repair 7 05-01-2005 05:40 PM
wierd Zenith RPTV, or, "if I had a hammer" JURB6006 Electronic Repair 3 09-17-2004 12:53 PM
Sony KPR-46EX32 RPTV intermittent picture randy Electronic Repair 3 07-29-2004 08:04 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93
