Are the other associated diodes all marked with the same identification? If
so connect one of them to a circuit using a variable voltage and current
limiting resistor. Ramping the voltage up and montioring it across the
diode, it will be obvious when you reach the zener voltage, start low then
bring the voltage up gradually.
Examine the circuit for electrolytic caps near the diodes, this may indicate
roughly what voltage range the diodes may be. As Leonard posted, some of
these are used for protection, as a crowbar device.
"Leonard Caillouet" <(E-Mail Removed)> wrote in message
news:CJpni.502$(E-Mail Removed)...
> Some context on the application is needed if you can't find a schematic or
> parts list. Zeners are usually used for either protection or as a
> reference. What is it connected to?
> Leonard
> "Choong" <(E-Mail Removed)> wrote in message
> news:469de17f$(E-Mail Removed)...
>> Hi everyone, I am repairing an industrial PSU and there is a few glass
>> types zener diode on board and I found one which is shorted but the
>> problem with these small glass type zener is that it is only marked with
>> the numeric "123" and nothing more than that so how do I know what is the
>> zener voltage of this diode?
>> Thanks
>> Choong
