On 24 Feb 2006 19:36:17 -0800,
(E-Mail Removed) wrote:
[snip...snip...]
>5) is there a way to give the fan full juice at start-up and then
>restrict the juice to the same speed that the 5.1v 1A zener puts out.
>I like the speed of the fans that these zener made them spin (once they
>actually start), but it seems like they need more power to start
>turning. I believe regulators do exactly that - is that true and if so
>what type do I need?
There are "pulse-width modulated" (PWM) regulation schemes that can
start with a 100% duty-cycle for some period of time to kickstart the
fans, which then revert to lower duty cycles that are proportional to
the temperature at some sensing point.
The easiest approach to this (for me) would be a little 8-pin
microcontroller with an internal oscillator and a thermistor (or two)
hanging off of an A/D port. That also makes it easy to enforce a minimum
fan speed, to close the loop and monitor fan speed, as well as to take
action (sound an alarm, shutdown the device, etc.) if the temperature is
too high or if the fans fail.
>6) are there any other electrical options to slow down my fans?
Understand that, to a first approximation, the expected time to failure
of the projector is directly proportional to the fan speed; the slower
the fans run, the hotter the projector will get, and the sooner it will
fail. If you're lucky, it will just be the bulb...
You *may* be able to achieve both cool and quiet operation if you open
the case and use a larger but slower fan to move an equivalent amount of
air over the works. This has the down side of potentially exposing
you/kids/pets to mains voltage. Or, put the whole thing in a sound-proof
baffle box and use the large-but-slow fans to push/pull room air through
the box. It may be enough to use a "half box" (fully open on one or two
sides) lined with "egg crate foam" to muffle the fan noise without
needing to add another fan.
Rich Webb Norfolk, VA
