Electronics Forums
Electronics Forums > Electronics Forums > Electronics Repair > Wierd keyboard problem
Reply
Thread Tools Display Modes
Junior Member
      05-15-2011, 08:22 AM
Sorry that my first post is a help question but I couldn't find any specific information anywhere else.
I have an old electronic keyboard/synthesiser - Technics KN500 circa 1994 - which when played loudly, cuts power and the unit turns off. The keys are touch sensitive so the harder you press the louder the note.
It usually takes playing a big chord quite loudly for the unit to switch off. If I turn the master volume down then I can bang on it as much as I want and it stays on. Every other function of the unit works normally.
I have medium level of electronics knowledge and after opening the unit I couldn't see any obvious compent problems.
If I had a better idea of what might be causing the issue (ie. what type of componentry regulates the master volume) I might be able to narrow it down.
Thanks for reading.
Super Moderator
(*steve*)'s Avatar
Location: Mid way between Beijing and the the Ronne Ice Shelf (mind your projection) ...and don't call me Sir!
      05-16-2011, 12:48 AM
Does the unit turn off immediately the loud sound is played? Or does it take a period of loud playing?
Describe the "tuning off" -- does it appear totally like the power is off (including any power lights) or is is simply mute?
Are there any heatsinks inside? Do they get warm or hot? and do the transistors connected to them seem distinctly hotter than the heatsinks?
Is the sound distorted, especially just prior to the unit turning itself off?
Junior Member
      05-16-2011, 03:56 AM
Hi steve,
All power to the unit is lost as soon as a loud chord is played. Its been a while since I've had it open so I'm not sure about the heat sink or trannies. I'll open it up tonight and have a look. I probably should have stated the power supply rating etc so I'll get that too.
Thanks.
Super Moderator
(*steve*)'s Avatar
      05-16-2011, 06:41 AM
If it switches off very quickly, then it's less likely that something is heating up.
It could be that the power supply shuts down when overloaded.
If the latter proposition is true, then either something is drawing too much current, or the overload detection has a fault (and is triggering on too low a current)
Senior Member
MattyMatt's Avatar
      05-17-2011, 07:10 AM
A quick question, when you are playing this loud chord, are you doing this while its on batteries or an external power supply (wall wart?).
I'm thinking if it is a wall wart, its possible the problem may lie in that as well... just a quick thought.
"One must be sane to think clearly, but one can think deeply and be quite insane."
- Nikola Tesla
Junior Member
      05-18-2011, 04:48 AM
The issue happens when connected to mains power (240V in Australia), when connected to a 12 V source or even when only running on batteries.
Steve, I think an overload detection fault is sounding quite likely. I'm not too sure how I would diagnose that but I'll start researching.
Thanks.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
LED moving message sign programmed with IR keyboard: Missing keyboard...possible solutions? 427Cobraman Electronic Repair 5 10-26-2006 01:15 AM
Just in case: (cherry keyboard pinout) - it was: help on soldering a 5 pin din connector to a keyboard Lotas Electronic Repair 0 06-09-2006 10:27 AM
Lubricant for a wierd problem siliconmike Electronic Basics 10 06-26-2005 07:23 AM
wierd problem with PIC18F, advice needed Alexandre Bezroutchko General Electronics 2 09-18-2004 11:48 AM
NAP PTV 375 wierd vert problem JURB6006 Electronic Repair 2 01-30-2004 06:25 PM
