Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electronic Basics > White Noise Source
Reply
Thread Tools Display Modes
White Noise Source
Chiron
Guest
Posts: n/a
      02-09-2012, 07:13 AM
I need a source of white noise (audio). It doesn't have to be perfect.
I seem to recall that you could use a zener diode as a white noise
source. Is this true? Are there any other possibilities? I anticipate
using a 9-V battery for my power, and a few transistors to amplify the
signal to drive earphones.
You may ask, "why the heck would he want to do that?" Good question:
http://en.wikipedia.org/wiki/Electro...ice_phenomenon
Since I believe that the chances of there being anything to this are just
about zero, I don't want to invest a whole lot of effort in doing it.
Do not apply to broken skin.
Phil Allison
Guest
Posts: n/a
      02-09-2012, 11:23 AM
"Chiron"
** I think you will find this microwave sauce recipe most satisfactory:
http://allrecipes.com.au/recipe/1083...ite-sauce.aspx
Not to mention tasty too.
And may I supply a word of advice -
leave the imaginary voices to the experts -
ie the genuine schizophrenics.
.... Phil
Bob Masta
Guest
Posts: n/a
      02-09-2012, 01:09 PM
On Thu, 09 Feb 2012 08:13:16 GMT, Chiron
Download my Daqarta software... it's free for signal
generation use. Midway down the Generator dialog, click the
left Waveform Controls button. Click Wave on the dialog that
appears and select Noise: White. Toggle the Generator
button on in the main toolbar. The first time the Generator
goes on the volume control dialog will pop up, plus a
cautionary message about loud levels. You'll need to cancel
the message before the sound starts. (In WinXP you may also
need to unMute, at the bottom of that dialog.) Later, you
can open the volume dialog via the F9 key at any time.
Now I'm going to give away a secret: In the next version of
Daqarta (v7.00, in a month or so) there will be a whole Help
section on EVP-related stuff, and a demo on how to hear it
for yourself. Well, not exactly what the woo-woo folks are
talking about, but a phenomenon I call "Phantom Signals"
that I think is at the root of the EVP nonsense... as well
as "dental radio".
The trick for phantom signals is to use headphones and put
the white noise in *one ear only*. The loudness should be
about 30-40 dB above your detection threshold. (You'll need
to be in a fairly quiet room, with no music, TV, or voices.)
I'll provide a simple way to set that level. Let me know if
you want me to explain a manual approach here. It's not
super-critical, but it needs to be loud enough to hear
easily, but not too loud.
Listen for a few minutes, and you will start to hear a
"radio station". You might hear music or voices, but you
won't be able to tell exactly what the song is, or
understand what they are talking about... nevertheless
you'll be convinced there is a "signal" there. You might
categorize the station as "Country", or "Talk Radio", or
whatever, based on what you hear. You'll probably have an
overpowering feeling that if only you could just improve the
S/N a *teeny* bit you would understand everything. But you
can't.
And if you switch the noise source to *both* ears, the
phantom signal vanishes and you just hear noise. (Sometimes
you can get the effect with both ears, but it may take a
*lot* of listening.)
I actually discovered this a long time ago, while designing
a diode-based noise generator. Since that sort of circuit
involves a lot of gain, when I heard the "radio station" I
naturally assumed that's *exactly* what it was hearing. I
tried all kinds of filtering before I finally got rid of
it... coincidentally having switched from a single-ear
lineman's test set to stereo phones. Problem solved!
Then I built a completely digital version, which doesn't
involve gain and is not susceptible to AM pickup... or so I
assumed. Yet it was back again, but only with the mono
headset, not stereo or speakers. Took a lot of testing to
convince myself that it wasn't a circuit problem... at least
not in my hardware circuit, only the "wetware" between my
ears!
Then when I showed the phantom signals effect to others they
were absolutely convinced it was a real radio station, and
that there was some defect in my hardware. Had to go
through all the steps with them to prove it was only in
their heads. The really convincing proof was that it
vanished instantly when heard through both ears... hard to
explain if it was AM pick-up!
For a long time I didn't want to announce this to the
general public because I hoped to recruit subjects for an
unbiased test. But that got put on the back burner for so
long that I've given up on it.
So enjoy!
Best regards,
Bob Masta
DAQARTA v6.02
Data AcQuisition And Real-Time Analysis
www.daqarta.com
Scope, Spectrum, Spectrogram, Sound Level Meter
Frequency Counter, FREE Signal Generator
Pitch Track, Pitch-to-MIDI
Science with your sound card!
Oppie
Guest
Posts: n/a
      02-09-2012, 01:32 PM
"Chiron" <(E-Mail Removed)> wrote in message
news:weLYq.15012$(E-Mail Removed)...
Zeners do work. I had used a 6V zener feeding it through a 1 meg resistor
from 15V. The spectrum was lacking in much of the audio range though. I had
better success reverse biasing the base-emitter junction of any garden
variety transistor. The NPNs that I tried break down in the range of 8
volts, so again, a 1 Meg feed from 15V is a good starting point.
the '15V' can be either from two 9V batteries or a boost converter.
OR you can look up "white noise schematic"
Pseudo Random Noise can be digitally generated with a recirculating shift
register that has the feedback tapped at a few points and XORed as shown in
this diagram
http://www.discovercircuits.com/DJ-C...s/noisegen.htm
It shows 12V power but modern logic elements will work at lower voltages. I
used a similar circuit for calibrating a sonar system (signal of interest
burried in 90 db of noise).
Chiron
Guest
Posts: n/a
      02-09-2012, 01:42 PM
On Thu, 09 Feb 2012 09:32:55 -0500, Oppie wrote:
<snip>
Thanks, Oppie. I might try the idea with the transistor. Seems like it
might be what I'm looking for...
Exercise caution in your daily affairs.
Chiron
Guest
Posts: n/a
      02-09-2012, 09:15 PM
On Thu, 09 Feb 2012 13:28:04 -0800, George Herold wrote:
<snip>
> I really like 20V 1/2 watt zeners for this... bias from +/-15 volts
> through a 1 meg resistor. Lotsa noise and flat out to ~500kHz or so.
> The voltage is a bit asymmetric, but that can be fixed..... by adding
> two of opposite polarity.
Thanks, George. Is there anything special about the zener being 20V? In
other words, would a 20V zener be better than using, say, a 5.1V?
Tart words make no friends; a spoonful of honey will catch more flies than
a gallon of vinegar.
-- B. Franklin
BeeJ
Guest
Posts: n/a
      02-09-2012, 09:36 PM
on 2/9/2012, Chiron supposed :
> <snip>
Yes, the higher voltage zeners have a little negative resistance in
part of their curve. That is why you can build an oscillator using
just the diode a capacitor and resistor. Try it. Fun.
Look closely at the curves on the higher voltage zeners.
Chiron
Guest
Posts: n/a
      02-10-2012, 01:04 AM
On Thu, 09 Feb 2012 17:46:23 -0800, George Herold wrote:
> Yeah a big difference. In low voltage Zeners the current is from
> tunneling electrons (one at a time) and only have shot noise. (Which is
> pretty small). High voltage 'Zeners' do this avalanche break down...big
> random current pulses.
> Lot's more noise 'amplitude'.
> I looked at a bunch of different voltages. (Above somethiing like 6V is
> where you start to get some avalanching.) 10 and 12 Volt Zeners showed
> more than shot noise, but there was a lot of part to part variation in
> the amount of noise. For some reason* 20V zeners all give about the
> same signal levels... I posted a 'scope shot some time back.
> If you use glass encapsulated diodes then wrap some black electrical
> tape around them... else the room lights leak in and ruin everthing.
<snip>
This is interesting. Who knew there was so much to something as
(seemingly) simple as a zener diode? Not me, anyway.
Thanks for the info.
Afternoon, n.:
That part of the day we spend worrying about how we wasted the
morning.
I'm a soldier, not a diplomat. I can only tell the truth.
-- Kirk, "Errand of Mercy", stardate 3198.9
Chiron
Guest
Posts: n/a
      02-10-2012, 01:16 AM
<snip>
Never even thought of that; I'll do it.
> shift register that has the feedback tapped at a few points and XORed as
> shown in this diagram
> http://www.discovercircuits.com/DJ-C...s/noisegen.htm It shows 12V
> power but modern logic elements will work at lower voltages. I used a
I think I recall something similar from Don Lancaster's CMOS Cookbook...
but IIRC, the "noise" repeated. Not sure whether that would be a
problem, though...
Anyway, thanks for the ideas.
Some of us are becoming the men we wanted to marry.
-- Gloria Steinem
Michael Black
Guest
Posts: n/a
      02-10-2012, 02:49 AM
> <snip>
> problem, though...
It depends on what you want, and how long the sequence is.
Sound generator ICs like the AY-5-8910 (I think I got that number right)
or those from Texas Instruments used that scheme. If the sound generator
in the Commodore 64 included a white noise source (I can't remember), then
it used that scheme.
For a while in the seventies, National Semiconductor had an IC that
generated noise using that scheme, it was sold as a "pink noise
generator", where you'd add an external filter to make the noise "pink".
Another company had a similar device.
Of course, PAIA just used a 2N2712 for the noie source in their projects.
It was never clear if they found that device was better at it, or if they
just found a cheap device.
Michael
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Spice White Noise Source D from BC Electronic Design 7 12-22-2006 04:03 AM
randomized white noise = white noise? acannell@wwc.com Electronic Design 40 05-27-2006 05:23 AM
White noise generator Roger Dewhurst Electronic Basics 31 12-29-2005 12:59 AM
white noise from stereo amp Choreboy Electronic Repair 4 08-15-2005 03:53 PM
White Noise Paul Burridge Electronic Design 18 01-10-2005 04:16 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98
