Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electronic Design > Want a 1-minute video delay
Reply
Thread Tools Display Modes
jtaylor
Guest
Posts: n/a
      07-06-2004, 11:30 AM
Just saw a diving coach with a dvd-ram recorder doing "time-slip" - the box
records in real time and plays on about a 30 second delay. This was a
_great_ system for coaching.
This box costs too much for me, I don't need to record, and I want at least
1 minute of delay.
Is there either a hardware or software solution?
Rene Tschaggelar
Guest
Posts: n/a
      07-06-2004, 11:41 AM
> 1 minute of delay.
It all amounts to storing this one minute.
Usually done with a harddisk.
Rene
Ing.Buero R.Tschaggelar - http://www.ibrtses.com
& commercial newsgroups - http://www.talkto.net
Ian Stirling
Guest
Posts: n/a
      07-06-2004, 11:47 AM
> 1 minute of delay.
I've done this using linux.
Mplayer/mencoder, encoding to mpeg.
Start mencoder recording to file, start mplayer 30 seconds later.
Plus, you can skip back and forward in the playback file.
One wrinkle is that you can fall off the end of the file, and it'll
exit.
jtaylor
Guest
Posts: n/a
      07-06-2004, 11:59 AM
Rene Tschaggelar <(E-Mail Removed)> wrote in message
news:40ea9034$0$26643$(E-Mail Removed)...
box
least
> > 1 minute of delay.
Well, yes, that was obvious.
I've done some googling since posting; there are software video recorders
out there. Has anyone used one that has such a delay?
It's just ocurred to me that I might be able to start a video capture with
virtualdub or something similar, and just start a video file-player on the
capture file after 1 minute (or more). If I can get the file-player to read
the file even though it's in use that would work...
jtaylor
Guest
Posts: n/a
      07-06-2004, 12:15 PM
Ian Stirling <(E-Mail Removed)> wrote in message
news:%iwGc.3556$(E-Mail Removed)...
box
least
> > 1 minute of delay.
> exit.
Sounds good. What kind of cpu, ram, and disk space do you use?
This would have to run for about 1 hour of continuous video.
Ian Stirling
Guest
Posts: n/a
      07-06-2004, 04:10 PM
> box
> least
>> > 1 minute of delay.
>> exit.
I haven't checked more recent versions, it may be that the 'falling off'
has been fixed.
I have a duron 1300, 256M ram (128 would be quite adequate) 800G or so
of disk (2 or 3 free would be adequate)
I wouldn't go much below duron 1300, 256M, 40G disk.
This is with 384*288 25fps encoding, 44Khz stereo 196K.
It uses 50% CPU, and is pretty stable.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
How to delay out put video. khan3443 Electronics Homework Help 1 09-02-2010 10:38 PM
12vdc 10 minute Off-Delay Timer - Need help please. WinMXer Electronic Projects 2 12-08-2008 04:34 PM
Sony KV27S15 - 10 minute delay after power on Sean Collins Electronic Repair 13 07-04-2005 09:07 PM
Radio delay to sync with TV video larrybud2002@yahoo.com Electronic Design 26 12-23-2004 02:44 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98
