Electronics Forums
Electronics Forums > Electronics Forums > General Electronics Chat > volts and attenuation for microphone?
Reply
Thread Tools Display Modes
Member
      04-12-2012, 04:04 PM
hello there : )
ive set up this little pre-amp circuit, and it seems to work o.k. i am using a 5v regualated supply.
what i have connected to the input is cheap mic capsule from a cheap headset. i beleive the mic is an electret mic. the amp is not distorting as i replaced the 1k (R2) in the diagram to a 4.7k and that has helped allot. ( i am hoping that is the best place to attenuate the the level, before it goes into the amp? i could place a variable there perhaps?)
ive looked around and most descriptions of these electret mics say they need 2v or more.
i have measured the voltage +- at the mic it is just under 5v so that should be o.k.
i wonder, is there anything i can do to tune ths a little better? i thought to replace the mic capsule in the headset with a panasonic WM-55A103.
any ideas would be cool : )
Super Moderator
      04-12-2012, 06:25 PM
What do you want to tune?
- frequency response?
- gain?
- noise?
Member
      04-12-2012, 07:41 PM
hi
I think if I get a new capsule WM-55A103 it will sound allot better. i just wondered if all the values seemed o.k.? and if varying the 1k (r2) for pre attenuation before the amp is the best way to do this?
Super Moderator
      04-13-2012, 06:17 AM
Test it!
Harald
Senior Member
      04-13-2012, 02:59 PM
Or, calculate it!
The microphone module should indicate what it's output is. Set the gain so that you get the output level you want, presumably something like 1V P-P.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
HOW DO I REDUCE 12 VOLTS TO 6 VOLTS Electronic Basics 6 01-22-2005 06:29 AM
12 Volts 3 Amps DC vs 12 Volts 6 Amps DC Jerome Jahnke Electronic Basics 1 09-27-2004 07:22 PM
120 House Current Volts down to 1.5 volts How? Rob \ the nut \ Electronic Basics 7 06-09-2004 03:14 AM
11 to 30 volts --> 24 volts Jim Weir Electronic Design 17 05-28-2004 03:53 PM
voltage regulator, 12 volts in, 12 volts out CampinGazz Electronic Design 4 01-25-2004 07:26 PM
