Electronics Forums
Electronics Forums > Electronics Forums > Circuit Help > Voltage-controlled amplifier
Reply
Thread Tools Display Modes
Junior Member
      02-09-2010, 07:27 AM
Hi everyone, can someone help me analyse this circuit?
It is a Voltage-controlled amplifier using an op-amp(741) and a JFET(2N3819). Please provide all info. regarding :the component terminal connections, the formula for determining the gain using the compopnent numbers in the circuit; limitations of a 741 when used as an amplifier. Thanks in advance
Super Moderator
(*steve*)'s Avatar
      02-09-2010, 07:42 AM
If Q1 was shorted out, the gain of the stage would be R2/R3.
Q1 adds to the resistance of R3 by an amount determined by the gate voltage. So changing the setting on the pot changes the voltage on the gate of Q1, which alters one of the resistors in the feedback loop of the amplifier, which changes the gain.
Junior Member
      02-10-2010, 07:02 AM
Thanks Steve for your kind reply. For additional info, the junction field-effective transistor used herein is 2N3819. What must I do to get a voltage gain of exactly 5 if I adjust the variable resistor?
Super Moderator
(*steve*)'s Avatar
      02-10-2010, 09:18 AM
The variable resistor must be adjusted until the resistance across the FET is equivalent to R2/5 - R3
Alternatively (and perhaps more pragmatically) the pot needs to be adjusted until the voltage gain is equal to 5.
Without component values, and understanding that the characteristics of FETs vary somewhat from device to device it is hard to be particularly precise.
Junior Member
      02-25-2010, 11:22 AM
Ok, now let's add values:
C1= capacitor between 1 and 10 microfarad
RV1= 47k ohm; R1= 47k ohm; R2= 33k ohm; R3= 2200 ohm; R4= 47k ohm; R5= 10k ohm.
How is Vgs(off) calculated?
Super Moderator
(*steve*)'s Avatar
      03-09-2010, 02:36 AM
Vgs is a value you read from the specs of the device.
How they calculate it is probably of little concern. Essentially they make sure that the quoted voltage will not break down the diode formed at the gate junction.
edit: JFET, not MOSFET (so diode, not insulating barrier)
Super Moderator
(*steve*)'s Avatar
      03-09-2010, 02:40 AM
With those values, the gain will be variable from 1 to approx 10.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Common mode voltage in op amps Amanda Robin Electronic Basics 3 11-26-2005 05:26 PM
Hysteresis needed in 741 Op-Amp circuit John Fields Electronic Basics 0 06-14-2004 12:05 AM
Re: smps design, A to Z, help. John Popelish Electronic Basics 14 08-10-2003 06:06 PM
Re: smps design, A to Z, help. John Popelish Electronic Design 14 08-10-2003 06:06 PM
high voltage amplifier Alexander Electronic Design 6 07-21-2003 12:33 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33
