Pete wrote:
> Thanks John
> I have had no prior experience with OP-amps so this will be a pretty steep
> learning curve of which i am keen on pursuing if it will do the trick. Any
> chance that you would have a circuit schematic to use in conjunction with
> the LM7171 that would suit this application?
The video line driver on page 16 of the data sheet:
http://cache.national.com/ds/LM/LM7171.pdf
gives the general idea, except that the two resistors in the voltage
divider to the - input have to have a ratio of 4 to 1, instead of
being equal, to give an overall gain of 5 (say 510 to ground and 2k
feedback, with, perhaps a 100 ohm trim pot between them (with the
wiper to the - input) as a gain trim. And I am assuming that you
would put this right next ot your A/D input, so no series terminating
resistor would be needed on the output.
Read the application notes section for how to bypass the supply lines
for such a high frequency opamp.
John Popelish
