Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > General Electronics > Veroboard cutting and veroboard-layouting
Reply
Thread Tools Display Modes
Rikard Bosnjakovic
Guest
Posts: n/a
      03-16-2005, 08:30 AM
Greetings
As a newcomer to the wonderful world of electronics, I have recently
setup a minor electronics lab in my home and started to build a few
things. My tools and equipment exists of standard components (resistors,
capacitors, ICs, etc), soldering iron, a bunch of veroboards and a
multimeter. I do not, however, own an oscillator or any of those more
expensive tools like PCB-etching equipment and such. Atleast not yet.
As stated above, I'm using veroboards (stripboard and breadboard is a
synonyme for the same thing, i think) for building my circuits. I also
own a licence of Electronic Workbench (Multisim and Ultiboard are the
ones I use most frequently). However, since I do not own any etching
equipment Ultiboard is of less use for me since it can only do
PCB-layout/routing. I have contacted the developers to hear if there was
any possibility to make Ultiboard output to veroboards, but regretfully
enough UB is designed for PCB only, was the answer.
1. Is there any layout/routing-application that is able to output
layouts for veroboards? I have only found two cheap shareware-programs
on Google. Even if they work, they were terribly tedious to use (limited
amount of components etc). Is there no commercial or fully developed
program anywhere? A great plus would be if the program could read the
format that Multisim saves to, thus allowing me to save time by not
designing the whole circuit all over.
2. When constructing on veroboards, I often have the need in cutting the
boards to smaller shapes and I've found that it's pretty cumbersome
since I haven't found any good tips of how to do it the right way. For
new boards, I could take a small saw and shape it up without much
problems. But for new circuits that I haven't done before, cutting the
boards could lead to a too small board in the end, requiring me to start
it all over again.
Therefore I build new circuits on unmodified boards, so I get the whole
space to begin with and cut it down later. But here's the problem. When
I cut (not using a saw), the board usually tends to break up and it
seems it doesn't want to be cut in straight line. I've tried a long and
sharp knife, placing it between the lines of copper, and pushed hard.
But the board still tends to break up in pieces near the end.
Has anyone got a tip / link for me where I can read about how to cut
boards without any breaks?
Thanks in advance.
Sincerely, | http://bos.hack.org/cv/
Rikard Bosnjakovic | Code chef - will cook for food
Yukio YANO
Guest
Posts: n/a
      03-16-2005, 10:32 AM
Rikard Bosnjakovic wrote:
> Greetings
> Thanks in advance.
Next new/used toy ! E-Bay for a used Oscilloscope ~ $25/50 +s/h
Then breadboard a "555" timer for a signal generator, cost ~ $2.00
biggest expense ! $1.50 for a 9 Volt battery
Use a Jeweller's Saw ! Looks like a Coping Saw, only a little more refined
Find under Jewellery Making or Lapidary Supplies
"Michael's". "Hobby Lobby", "Walmart ? " ~$10.00 + blades
I have'nt bought a new one in years so Price is only a guess.
I've used a Dremel tool with 1" Abrasive cut-off wheels, but the
Jeweller's is much more elegent,
Yukio YANO
Ross Herbert
Guest
Posts: n/a
      03-16-2005, 11:11 AM
On Wed, 16 Mar 2005 08:30:46 GMT, Rikard Bosnjakovic <(E-Mail Removed)>
wrote:
>Greetings
None that I know of. If you think about it, Veroboard is intended for
prototyping only in order to verify a circuit design. Of course it
does have it's use as final board for a one-off design but essentially
it is used only for prototyping. It would not be viable for any
software designer to develop a layout package for Veroboard since the
ultimate goal for any product manufacturer who uses an electronics
module is to go to a standard pcb layout.
>it all over again.
Yes, the cut-after-fitting-components does make it difficult and is
only recommended for very small boards maybe up to 50 x 50mm. With
this approach I always cut with a 32tpi hacksaw blade with the blade
teeth flat across the copper strips or in between strips as the case
may be. You have to ensure that the board is held rigidly and this may
be difficult and also make sure that you use both hands to guide the
hacksaw frame and use small forward motions to start. When you have
scored the board to about half thickness it will then snap quite
cleanly such that a file will tidy up any irregulariies. Of course you
can cut to a greater depth to make it even neater.
The best way to construct larger boards is simply by proper planning
on paper. I draw out the physical shape of the components about 2x
scale on paper so that they occupy a logical arrangement according to
the circuit schematic. This can take a good deal of experience based
upon the characteristics of the individual components you are placing.
This knowledge only comes with years of experience so I can't give you
specific instruction in this regard. You can use lined paper so the
lines simulate the copper traces or you can use linear graph paper on
a 0.1" grid to draw it up full size. You need to work out where to cut
traces and where to add wire links to suit your design. Use a soft
black pencil and remember an eraser is your best friend The more time
you spend on the paper layout the easier it will be to add the
components to a piece of board which is pre-cut to its finished size.
Ol' Duffer
Guest
Posts: n/a
      03-16-2005, 02:02 PM
In article <W8SZd.19761$(E-Mail Removed)>, (E-Mail Removed) says...
I am not familiar with that package, but have used commercial
routing programs to do veroboard and thought it was a piece of
cake. At least compared to pencil, eraser, and graph paper.
Just snap to a 0.100" grid and remember that the traces on the
bottom only run one direction. No it won't tell you where to
make cuts, but is that really so hard to figure out?
> it all over again.
A bandsaw with a fine-tooth blade is a beautiful thing, but
a hacksaw can serve. With small boards, I sometimes find it
easier to clamp the saw in a bench vise and drag the board
across it.
Or with a little practice, you can score the board and break
it over a sharp table edge like you would a piece of glass.
It may help to cut through the foil at the desired break line,
as it is tougher than the board. The key is to create an
obvious path of least resistance.
Cut or score along the holes, as this is the weakest place,
and any random breaks will tend to occur here anyway. If you
need to trim down further to that 0.050" between holes, a
belt sander or bench grinder works well. Or a fine-tooth
file for inside corners.
Tomi Holger Engdahl
Guest
Posts: n/a
      03-17-2005, 09:53 AM
Ol' Duffer <(E-Mail Removed)> writes:
LochMaster claims to be a developers tool for strip board
(VERO) projects for designing, documenting and testing a board.
This is a commercial program.
LochMaster 3.0
http://www.abacom-online.de/html/lochmaster.html
Tomi Engdahl (http://www.iki.fi/then/)
Take a look at my electronics web links and documents at
http://www.epanorama.net/
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Veroboard- newbie question ben Electronic Basics 7 07-11-2006 08:59 AM
older style veroboard Peter Electronic Repair 3 05-09-2006 07:52 AM
Veroboard cutting and veroboard-layouting Rikard Bosnjakovic Electronic Design 14 03-18-2005 06:40 AM
Veroboard cutting and veroboard-layouting Rikard Bosnjakovic Misc Electronics 4 03-17-2005 09:53 AM
Can someone Clue Me in About Veroboard? Watson A.Name - \Watt Sun, the Dark Remover\ Misc Electronics 15 10-08-2004 02:18 AM
