Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Hobby Electronics > variable reluctance sensor/speed switch
Reply
Thread Tools Display Modes
stocky
Guest
Posts: n/a
      07-21-2003, 01:09 PM
I am building a speed switch around a LM2907, but want to add a "pulse" LED
that blinks every time the magnet goes past the senor....I'm having a mental
blank, i'm sure it's easy but can't think how to do it! Should I
capacitively couple the signal from the sensor, so it doesnt mess up the
signal goint to the '2907 and use something like a schmitt trigger to flash
the LED? I know the output amplitude from the sendor varies greatly with
speed, but I need the LED pulses to make it easy to setup. Ant suggestions?
Dan Hollands
Guest
Posts: n/a
      07-21-2003, 02:51 PM
It is not likely you can drive the LED directly from the sensor - you
probably need some type of high impedance device like a mosfet to go between
the sensor and the LED.
Dan Hollands
1104 State Road
Webster NY 14580
585-703-2963
(E-Mail Removed)
www.QuickScoreRace.com
"stocky" <(E-Mail Removed)> wrote in message
news:uCRSa.7273$(E-Mail Removed)...
LED
mental
flash
suggestions?
stocky
Guest
Posts: n/a
      07-22-2003, 11:33 AM
My next thought was do I put the output of the sensor into an opamp and
drive it to a fixed level square wave, then feed that to the LM2907 and the
schmitt trigger (maybe via a cap). That would get me around the varying
input levels. yes?
"Larry" <(E-Mail Removed)> wrote in message
news:(E-Mail Removed) om...
> "Dan Hollands" <(E-Mail Removed)> wrote in message
news:<o5TSa.164294$(E-Mail Removed)>. ..
between
> > Dan Hollands
> > 1104 State Road
> > Webster NY 14580
> > 585-703-2963
> > (E-Mail Removed)
"pulse"
> > LED
> > mental
the
> > flash
with
> > suggestions?
> A schmitt trigger would be a good way you will set the on time (LED)
> and at high speed the trigger would be so fast that you may not see it
> and as you noted the input loading would be reduced.
> Hope it helps
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Switched Reluctance Motor Controller design seshu Electronic Design 1 01-28-2008 04:34 AM
Questioning the math Re: reluctance amdx Electronic Design 11 10-28-2006 12:52 PM
Help Re:(a term) calculating reluctance amdx Electronic Design 3 10-24-2006 10:16 PM
Variable reluctance magnetic pickup signal conditionner Jacques St-Pierre Electronic Design 26 08-31-2004 10:48 PM
variable reluctance sensor/speed switch stocky Beginner Electronics 2 07-22-2003 11:33 AM
