Electronics Forums
Electronics Forums > Electronics Forums > General Electronics Chat > Variable power supply
Reply
Thread Tools Display Modes
Member
      12-30-2011, 10:38 PM
I need to make a variable power supply which the out put voltage has to be from 3-15v ,1.5A,
I am going to use the lm317T . I am using the formula V= 1.25x (1+r1/r2)
and as v i placed 15 v . how am i going to make the minmum output voltage as 3v?
Thanks and happy New year
Senior Member
      12-30-2011, 11:09 PM
The LM317T needs a potential divider to set the output voltage as you have determined. There are two resistors in this divider, R1 and R2.
The LM317T controls the passes current to get 1.25V between the output and the sense terminal. The easiest way of detrmining the resistors is to decide on a current through the divider. Let us say 1mA, then Rupper will need to be 1.25k.
The rest of the output voltage is across Rlower, in this case, 3V - 1.25V = 1.75V so you will need a resistor of 1.75k to pass 1mA.
Check this with your formula. If the voltage is not critical, go for the nearest preferred values i.e. 1.2k and 1.8k.
Member
      12-31-2011, 11:30 AM
Tnks for the reply but i still have a question.
So than how can i make the power supply go up to 15v if the resistors selected in the circuit are calculated for 3v .
I know that i have to enter a variable reisistor but my question is how i am going to do the calculations to make it from 3v to 15v
Super Moderator
(*steve*)'s Avatar
Location: Mid way between Beijing and the the Ronne Ice Shelf (mind your projection) ...and don't call me Sir!
      12-31-2011, 01:43 PM
you make one of the resistors variable (hint - the one with the variable voltage across it).
Check out the datasheet for more information.
Note that your input voltage will need to be at least a couple of volts higher than your output voltage (the specs contain more information), and you will require a hefty heatsink for maximum current at minimum voltage.
Senior Member
      12-31-2011, 01:45 PM
its called algebra. 15V = 1.25(1+R2/240) then you solve for R2. R2 = 2640Ohms. Fit a variable resistor larger then 2640Ohms and you will achieve 15V
BTW, you formula was wrong, have another look at the datasheet. It is listed right under the first diagram. Where is says typical applications on the second page. http://www.ti.com/lit/ds/snvs774l/snvs774l.pdf
Member
      12-31-2011, 03:24 PM
Tnks for telling me that i need to use algebra.
I worked with that formula and I obtained 15v but when i varry the pot it does not go down to 3v .
do you think i have to place a zener diode some were or i did a mistake some were ?
Sry for the bad quality max volt is 15v and the minimum is 1.64
Tnks
Senior Member
      12-31-2011, 06:09 PM
Well if it went to 1.64V then it surely will output 3V. If you don't want it to go below 3V, then use a regular resistor to give you the 3V min and then in series add a pot to get your max V. When the pot is at 0Ohms, then 3V will be the min.
Senior Member
      12-31-2011, 08:01 PM
R2 the lower resistor can be made up of a fixed resistor to limit the lower voltage in series with a variable resistor to control the output voltage. The potentiometer should have one end and slider connected to ground and the other end connected to R1 and the reference input.
With R1 = 240 ohms = 1.25V, then 10 times this value on R2 will give 12.5 + 1.25 out = 13.75V.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Re: Variable in to variable out DC/DC converter SMS Electronic Design 0 08-17-2011 06:38 PM
high current variable power supply from ATX PC supply? Jake Omega Electronic Design 1 10-10-2009 05:20 PM
Variable speed cordless drills not variable? John Doe Electronic Design 1 07-04-2007 10:31 PM
Basic project: Want to build a basic power supply with variable voltage/amp output Chris Electronic Basics 1 01-01-2004 03:17 PM
variable power supply problem Mike R Electronic Basics 2 11-03-2003 11:47 AM
