On May 19, 10:07*am, bz <bz+...@ch100-5.chem.lsu.edu> wrote:
> "Dave Plowman (News)" <d...@davenoise.co.uk> wrote innews:(E-Mail Removed):
> > In article <Xns9AA1BC2E27A24WQAHBGMXSZHVspamm...@130.39.198.1 39>,
> > * *bz <bz+...@ch100-5.chem.lsu.edu> wrote:
> >> This means that you can regulate the 'open circuit voltage'. You would
> >> want to make sure that never exceeds your battery voltage by more than
> >> a few percent.
> > IMHO the charge voltage is pretty irrelevant. It's the current that
> > matters.
> Here is a current regulator that can be used for 0-2A with supplies that
> don't have current regulation built in.http://kd1jv.qrpradio.com/vps/voclps.HTM
> bz
> please pardon my infinite ignorance, the set-of-things-I-do-not-know is an
> infinite set.
> bz+...@ch100-5.chem.lsu.edu * remove ch100-5 to avoid spam trap
Hey thanks everyone for all the great answers. I have been busy and
not returned (and I thought the thread had sort of faded away).
bz, what is the purpose of regulating the current, when the power
supply can supply current from 0 to 10 amps (or if I parallel the two
PS in it, 20 amps)?
Al, thanks. When people charge batteries directly with these PSs they
do use a diode. I may do that eventually but for the moment am using
the PS to power pretty smart chargers. In that situation your idea of
having the bulb in circuit is brilliant, it's a way to monitor charge
status. Cool.
Mike, this is down the road, and why I got this monster:
http://www.youtube.com/watch?v=bSfTx4csNsw
Thats' 44 volts he's putting in those batteries starting at 10 amps,
and as you can see it just takes a few minutes to replenish a pack
that holds 2300 mah. The objective is to charge a pack in the same
amount of time it will keep your plane in the air, so with a couple
batteries and the Mastech PS, you can fly all day. People either use a
Honda generator/inverter or a couple deep cycle marine batteries with
an inverter. This is not a cheap hobby. Probably more than you wanted
to know but.....
Thanks to your help I set the voltage at a little over 12 (since I
dont' have a diode between charger and PS), put the amps at max,
turned the PS on, connected it to the charger which was already
connected to the battery, and the charger nicely started pulse
charging the nimh transmitter pack. I'm so new to this stuff I was
afraid to turn the Mastech on which I just got. All is good now.
Wow, this is a great group and lot's of nice folks, I'll come back for
help and let you know how my learning curve goes.
Jim
