Gregory R. Ball wrote:
> Hi,
> What I'm trying to do is build a circuit from my computer, where I
> have a controller card I've built that can raise signals, to the wall
> sockets, lights, etc. I want to be able to turn on and off the power
> to the sockets, etc. by raising a signal on the computer. What I want
> to do is run twisted pair wire through the walls and control it via
> that.
> I've done a bit of research and I think I can use a solid state relay
> like jameco part number 164988 for this. Do I just put it in series
> with the A/C current? And run the twisted pair to the input voltage
> leads?
> I'd also like it to default _on_ if the computer is yanked out of the
> wall or something, not necessary but a big plus (it would be nice to
> have electricity if the computer breaks).
> Any feedback would be greatly appreciated. I don't feel like burning
> down my house.
> Thanks,
> Greg
Greg,
Have you considered using X-10 controllers for the lights and such? You
can buy an interface for your PC to generate the control signals to
control these devices.
If you want direct control. Use solid-state relay that have logic level
inputs and connect them to a spare printer port. Turn individual port
bits on and off with software in the PC. Mount the relay as close to
the lamp, socket whatever, then you only need to run low voltage (5v)
wiring to them.
Luhan Monat
"LuhanKnows" At 'Yahoo' dot 'Com'
http://members.cox.net/berniekm
