Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electronic Repair > UPDATE: CD Rom Drive and Floppy Disk Drive, Same Type of Problem at the Same Time!!!
Reply
Thread Tools Display Modes
Brad
Guest
Posts: n/a
      09-16-2006, 12:14 PM
Note: I cleaned both drives, floppy & CD, (Compaq Presario 1060 laptop
yr 1997) but problem remains. I used a "lab" type of power supply as
substitute for latpop's external power supply. Also, see original post below.
More tests made since my original post exposed something very interesting.
I used Compaq's diagnostic software for this model laptop, which I transferred
using "PC Link" since floppy drive has trouble reading disks. Testing CD rom
drive, I placed a commercial (not home "burned") CD (AOK!). In fact, the CD
drive can easily read any of the commercial CDs I tried, but it can NOT read
a single home "burned" CD. Other computers can easily read the "burned" CDs.
Commercial made CDs use a different process compared to home 'burning".
Apparently the commercial CD's have "stronger impressions"?
Sometimes, a floppy disk can be read in part, then "hangs". Note: There
is no "Abort, Retry...." message as you normally see when you have a
faulty disk or no floppy disk in the drive. Writing to a floppy sometimes
looks like something is being written, but checking disk on another computer,
nothing is there.
I searched the web (HP/Compaq doesn't have it) for a schematic source (no
luck). I suspect a faulty voltage regular (common to both drives) is "under
powering" those drives? Note: No problem with the HD. If you have a better
idea, please let me know
Thanks in advance, Brad
On Mon, 04 Sep 2006 21:29:05 GMT, (E-Mail Removed) (Brad) wrote:
> My cousin asked me to repair his Compaq Presario 1060 laptop (Windows 95)
>which developed two problems at the same time!!!
> One of the two problems has to do with the floppy disk drive which
>suddenly has trouble reading floppy disks. The other problem (started around
>the same time as the floppy drive problem) has to do with the CD rom drive.
>That too has trouble reading CD rom files!!! Note: Using it's external power
>supply, which I had tested under load (AOK), the problems still exist.
>Note: This laptop was not damaged by a storm.
> The hard disk drive works just fine. Is there something that could have
>effected both the floppy drive and the CD rom drive, but not effect the HDD?
> Before you type your password, credit card number, etc.,
> be sure there is no active keystroke logger (spyware) in your PC.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Delayed Problem with Floppy Disk Drive Brad Electronic Repair 2 12-03-2006 05:46 PM
UPDATE: CD Rom Drive and Floppy Disk Drive, Same Type of Problem at the Same Time!!! Brad Electronic Repair 0 09-19-2006 11:27 AM
CD Rom Drive and Floppy Disk Driver, Same Type of Problem at the Same Time!!! Brad Electronic Repair 0 09-04-2006 09:29 PM
Repairng Proprietary FDS Floppy Drive. Quick Disk drive Michael Kennedy Electronic Repair 5 10-08-2005 04:10 PM
Re: Floppy Disk Drive Edward Cit Beginner Electronics 0 08-24-2003 12:44 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93
