(E-Mail Removed) wrote:
> I've got a 250W electric strimmer with a commutator type motor. It is
> running much more slowly than it should (I would guess a few hundred
> instead of few thousand rpm). Both brushes spark as it runs.
> I have checked rotor windings with a multimeter across the brushes,
> rotating the rotor readings hover around 20-40 ohms.
> There are no obvious high or low points on the commutator, and I have
> polished the contacts and cleaned them and the gaps between with
> methylated spirits.
> The brushes are about 15mm long, and are held snug against the
> commutator by springs
> The field (stator) windings are also about 30 ohm each.
> The rotor spins fairly freely, there is one point where it rubs
> slightly, but only very slightly.
> Can anyone suggest what might be wrong?
> Regards,
> Nigel
Are you sure it's a universal motor? The string trimmers I've seen had
permanent magnet DC motors with a diode in series. Check and see if the
diode is shorter or leaky, you could also run the motor on 12VDC, it
should run slowly but smoothly.
