Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electrical Engineering > What Type Of Surge Protected House Circuit Breaker ?
Reply
Thread Tools Display Modes
Robert11
Guest
Posts: n/a
      08-03-2005, 06:33 PM
Hello:
Will probably be replacing a standard house circuit breaker with a surge
protectot circuit breaker to provide protection for a furnace board that
seems to be pretty succeptible to lightning strikes (please see my previous
post). The furnace runs off a dedicated 15 amp line, protected by its own
breaker in the main house panel.
Apparently they come in two flavors.
One being the standard "surge protector," and the other type a "transient
voltage surge protector".
They both seem to be available incorporated into 15 amp circuit breakers
that fit in the main house panel box.
Which do I probably want ?
Why ? What are the differences re protection, etc. ?
ehsjr
Guest
Posts: n/a
      08-04-2005, 02:27 AM
Robert11 wrote:
> Hello:
> Thanks,
> Bob
Use a whole house protector instead. It goes in the panel
like a dual circuit breaker, and protects both both hot
legs. You also want a *good* grounding electrode system.
And bond your ductwork.
As to differences between devices, you'll need to read
the specs for each device you consider.
Ed
SQLit
Guest
Posts: n/a
      08-09-2005, 09:28 PM
"Robert11" <(E-Mail Removed)> wrote in message
news:EqWdnSrTX8xokGzfRVn-(E-Mail Removed)...
> Hello:
previous
> Thanks,
> Bob
I have never seen a panel surge arrestor in a 15 amp breaker.
http://www.mikeholt.com/onlinetraini...?id=1088534718
A lot of folks inter change the two words frequently
http://www.geindustrial.com/cwc/prod...d=0&lang=en_US
This page has the "breaker" type of protector that I installed. All panel
manufactures make them now days.
Panel installed with out wires are better cause the distance from the TVSS
to the buss is shorter.
No bigger wire has little effect on transients.
I also have plug strips TVSS that are at the point of use.
You will have to asses your risk and get what you need. Do not forget to
protect the cable, Sat and Telco wiring.
Odds are nothing you install will help on a direct/near strike.
I drive an auxiliary ground rod 10 feet way from the primary ground rod. I
try to get the lowest ohm path that I can.
w_tom
Guest
Posts: n/a
      08-10-2005, 04:07 AM
Siemens QSA1515.
SQLit
Guest
Posts: n/a
      08-11-2005, 09:02 AM
"w_tom" <(E-Mail Removed)> wrote in message
news:(E-Mail Removed)...
> Siemens QSA1515.
I will be a blue nosed gopher.
Thanks, for the lead.
I will stick to the dedicated products instead of combos like this.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Two surge protected receptacles on shared neutral Michael Moroney Electrical Engineering 0 04-18-2012 05:57 PM
Re: Circuit Breaker In A House Sercice Box Question Palindrome Electrical Engineering 1 04-08-2008 09:04 PM
Re: Circuit Breaker In A House Sercice Box Question phil-news-nospam@ipal.net Electrical Engineering 0 04-08-2008 03:18 PM
Compatibilty between siemens type qpf breaker and Cutler hammer type br Zarf Electrical Engineering 1 07-23-2005 04:17 AM
Bought a house with a Fuse Box. Should I replace with a Circuit Breaker? Zack Schneeberger Electronic Basics 15 02-23-2005 09:48 PM
