Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electronic Basics > Two Bridge Rectifiers In Parallel
Reply
Thread Tools Display Modes
Bret Cahill
Guest
Posts: n/a
      01-08-2006, 04:15 PM
Two otherwise identical 2 phase ac sources are 90 degrees out of phase
and you want to convert them to a single dc power supply.
Is it possible to simply use two bridge rectifiers, one for each ac
source and then connect the + output from one bridge to the + from the
other, etc.?
Assume the variation in dc voltage isn't an issue as it should be
attenuated somewhat anyway.
Bret Cahill
Tim Williams
Guest
Posts: n/a
      01-09-2006, 02:17 PM
Yeah, that's a two-phase rectifier. A three-phase rectifier has a FWB on
each of three phases, each 120 degrees apart. Two phase is two pairs of
wires, one 90 degrees ahead or behind (depending on your point of view) the
other. Since the peaks do no coincide, it will work just fine.
Tim
Deep Fryer: a very philosophical monk.
Website: http://webpages.charter.net/dawill/tmoranwms
"Bret Cahill" <(E-Mail Removed)> wrote in message
news:(E-Mail Removed) oups.com...
> other, etc.?
> Bret Cahill
Geir Klemetsen
Guest
Posts: n/a
      01-09-2006, 04:09 PM
"Bret Cahill" <(E-Mail Removed)> skrev i melding
> other, etc.?
Yes, you'll end up with a DC voltage with much less ripple
John Popelish
Guest
Posts: n/a
      01-09-2006, 05:32 PM
> other, etc.?
> Bret Cahill
It works fine as long as the two sources of AC are either isolated
from each other, or all ends equally swing positive and negative
around a common node.
Bret Cahill
Guest
Posts: n/a
      01-10-2006, 01:58 AM
The sources would isolated until they reached the bridge.
Actually I was interested eliminating two reciprocating cylinders &
crankshaft by piping two "liquid pistons" through a check valve bridge
to power a turbine.
I'll search Google for a check valve bridge. It may be something that
is only useful in theory.
Bret Cahill
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Double Bridge Rectifiers Purpose DAVIDHILLS General Electronics Chat 1 10-08-2008 02:40 PM
paralleing bridge rectifiers Jon Slaughter Electronic Basics 21 04-20-2007 02:32 AM
Re: FA: Motorola MDA1591-3 Solid-State Bridge Rectifiers octal tube base (20 N.O.S.) prototech@usa.net Electronic Components 2 08-09-2006 01:00 PM
Testing a full-Bridge Rectifiers diode Component mikuzj5@yahoo.com Electronic Repair 4 09-11-2005 07:48 AM
Very very simple question about bridge rectifiers Harry Muscle Electronic Basics 4 12-19-2003 06:21 PM
