Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electronic Basics > Twin Tee Sine Wave Oscillator
Reply
Thread Tools Display Modes
zero
Guest
Posts: n/a
      03-17-2005, 09:17 AM
How does a twin-tee sine wave oscillator work?
The schematic I have shows an op-amp with a twin-tee between the output and
the - input, and a voltage divider formed by a 10K resistor from the output
to the + input, and a 1K resistor from the + input to ground.
I understand that at the frequency w= 1/ RC the twin-tee produces a -180
degree phase shift. But at w= 1/RC, wouldn't the - input of the op-amp
become 0V because of the twin-tee's notch effect? Then the loop gain AB =0?
Andrew Holme
Guest
Posts: n/a
      03-17-2005, 01:04 PM
output and
output
-180
op-amp
AB =0?
The notch has finite depth, typically 60dB i.e. B = 0.001
The potential divider on the +ve input provides a little positive
feedback to make sure the oscillator starts reliably.
zero
Guest
Posts: n/a
      03-18-2005, 06:18 AM
If B = 0.001 would I have to change the voltage divider on the + input of
the op-amp to produce a gain of A = 1000 to keep AB = -1 at the desired
frequency?
"Andrew Holme" <(E-Mail Removed)> wrote in message
news:(E-Mail Removed) ups.com...
> output and
> output
> -180
> op-amp
> AB =0?
Andrew Holme
Guest
Posts: n/a
      03-18-2005, 10:15 AM
input of
desired
> frequency?
No.
For one thing: B is not 0.001; that's just a typical "ballpark" figure.
It will vary with component tolerances, temperature e.t.c.
Another thing: you can't control gain like that with POSITIVE feedback.
Sustained oscillation requires zero (or 360 degrees) phase shift and
unity gain. Due to temperature coefficients and component tolerances,
you can't get exactly unity gain, so oscillators are designed with
gains greater than unity. The question then is: what is the amplitude
limiting mechanism?
The amplitude may be allowed to grow until limited by the power supply
rails, the designer may use the non-linear characteristic of an active
component to limit the amplitude, or some form of automatic gain
control may be employed - whichever way it is done, the gain is
effectively unity!
The amplitude limiting mechanism affects the purity of the sine wave.
John Larkin
Guest
Posts: n/a
      03-18-2005, 08:20 PM
On Thu, 17 Mar 2005 09:17:33 GMT, "zero" <(E-Mail Removed)>
The positive feedback path wants to make it oscillate; assume it wants
to oscillate at all frequencies. The negative feedback through the t-t
overcomes the positive feedback and kills the oscillation. But at the
tt notch frequency, there is no neg feedback, so that's the only
frequency it can oscillate at, so it does.
John
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Re: Tee Hee! Tee Hee! Richard The Dreaded Libertarian Electronic Design 0 12-30-2008 11:44 PM
Re: Tee Hee! Tee Hee! Dirk Bruere at NeoPax Electronic Design 0 12-30-2008 09:33 PM
Re: Tee Hee! Tee Hee! JeffM Electronic Design 0 12-30-2008 09:24 PM
Re: Tee Hee! Tee Hee! nuny@bid.nes Electronic Design 0 12-30-2008 09:12 PM
Re: Tee Hee! Tee Hee! bulegoge@columbus.rr.com Electronic Design 0 12-30-2008 08:43 PM
