Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electronic Repair > TV power problem, relay clicks, only turns on when you hit it
Reply
Thread Tools Display Modes
lostintaipei@gmail.com
Guest
Posts: n/a
      05-29-2006, 07:24 PM
I have a Toshiba 27" made in 92.
There is a bit of a problem with turning it on. Turning off is always
fine. The remote doesn't turn it on, but I hear a relay click. Also,
doesn't turn on with the front switch under normal pushing...but also
hear a relay click.
The only way it turns on, is but hitting the front "ON" switch really
hard, to move or jiggle the set, or the hit the ON switch followed by
hitting the set in a certain sequence.
I believe it may be the relay, or some kind of mechanical part or
connection because you seem to need to hit the set to turn it on. Would
like some opinions before I pursue this farther. I'm not a TV repair
expert by the way.
Anyone have any suggestions... anyone know what the relay looks like?
Franc Zabkar
Guest
Posts: n/a
      05-29-2006, 09:41 PM
On 29 May 2006 12:24:20 -0700, (E-Mail Removed) put finger to
keyboard and composed:
>hear a relay click.
>expert by the way.
No kidding. :-)
It sounds like the set may have a dry joint. I suggest you reflow all
suspect solder joints before you make the problem worse.
It is usually rectangular with 4 pins. It may have a transparent case
through which you would see the coil and contacts.
- Franc Zabkar
Please remove one 'i' from my address when replying by email.
b
Guest
Posts: n/a
      05-30-2006, 11:41 AM
(E-Mail Removed) ha escrito:
> hear a relay click.
> expert by the way.
you will need to resolder the power supply and high voltage components
where heating and cooling cycles have led to the solder becoing
cracked. if in doubt, have a tech do this simple and hopefully
inexpensive work, or you could end up trashing the set.
-B.
Yukio YANO
Guest
Posts: n/a
      05-30-2006, 06:43 PM
With the back off the set, using a mirror, turn on the set using the
Remote !, Listen for the Relay to click ON !! and OFF. Should be close
to the back of the Set.
My guess is the relay is about to give up the ghost entirely, ie I
suspect the relay contacts are badly cooked.
This should come as no surprise after all, I would guess the tiny
contacts have switched ~ 500 watts about 20,000 times, over 15 years of use.
The QD. quick and dirty, is to permanently solder the appropriate traces
on the motherboard to leave the set ON permanently and turn OFF by
un-plugging the Set, or use a switched Power-bar.
The final cure will then be to replace it with a BIG SCREEN TV (HD),
partially paid for by forgoing the cost of replacing the Relay.
Yukio YANO
sofie
Guest
Posts: n/a
      05-30-2006, 08:07 PM
A wild guess.... to be sure!
Best Regards,
Daniel Sofie
Electronics Supply & Repair
"Yukio YANO" <(E-Mail Removed)> wrote in message
news:Cn0fg.214246$WI1.194537@pd7tw2no...
> Yukio YANO
Yukio YANO
Guest
Posts: n/a
      05-30-2006, 10:51 PM
Less wild than the two previous posters call for COLD SOLDER JOINTS !, I
would even bet a case of beer on it. We could get the O/P to umpire the
call.
Yukio
I traced the Relay on another TV with the same symptoms same way, was
surprised by how small it was. These contacts are supposed to last a
hundred thousand cycles !
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Sony DVP-NS700P DVD Player Turns On Then Turns Off Optik Electronics Repair 14 11-11-2011 01:38 AM
Re: Curtis Mathes TV CM27001S turns on, then turns off Brad Electronic Repair 0 06-06-2007 08:01 PM
Curtis Mathes TV CM27001S turns on, then turns off Brad Electronic Repair 0 06-05-2007 07:05 PM
=> This alarm OWL will hit you and wake you up -- Security Alarms 0 07-14-2004 03:38 AM
Basic transformer question - number of turns depends on frequency?(Not turns ration, number of turns) Al Borowski Electronic Design 22 04-12-2004 05:58 AM
