Electronics Forums
Electronics Forums > Electronics Forums > Electronics Homework Help > Transformer question
Reply
Thread Tools Display Modes
Junior Member
      08-12-2010, 01:10 PM
I was curious, for a transformer why is it that increasing the voltage reduces the amount of current that is transmitted?
SEO Link Building Service
Forum posting service
Super Moderator
(*steve*)'s Avatar
Location: Mid way between Beijing and the the Ronne Ice Shelf (mind your projection) ...and don't call me Sir!
      08-12-2010, 01:52 PM
Because the power remains constant (less any loss in the transformer)
power = voltage * current
(It's a bit more complex than that, but that is enough to show you why)
Senior Member
      08-25-2010, 05:24 AM
Good answer – even though the question is a bit misleading. To put it in concrete physical terms, any particular transformer design is limited in power output by its ability to effectively shed heat. Continuously overload a transformer of any size, and it will ultimately burn up through failure of its insulation system. Within the limits of any fixed size of transformer, there is a finite, fixed limit of allowable power loss. Increasing output voltage means increasing the number of secondary turns. With a given size core, to physically fit more turns on the secondary, the size of the secondary wire must be reduced. The additional number of turns also increases the total resistive length of the secondary winding. More turns / smaller wire = higher secondary resistance = lower output current at the fixed limit of allowable secondary power loss.
Super Moderator
      09-01-2010, 01:25 PM
While I doubt that the o/p (a spammer) will comprehend (or care) about neither the question nor the answer, someone else might benefit. Thanks.
Senior Member
      09-02-2010, 04:35 AM
Thanks for "scraping" up the spam, Resqueline - I never spotted it - and though I have to admit I eat the greasy canned variety from time to time, I never appreciate having the other kind jammed into my face!
Super Moderator
      09-02-2010, 09:05 AM
Hehe, yes, even if canned & greasy some kinds are certainly more "digestible" than others. Then there are the grey areas too.
They devise ever changing ways so one has to be really vigilant, and some can be hard to distinguish from simply "unenlightened" individuals.
The latest "fad" seems to be editing in a link a couple of days after posting the first seemingly lame but harmless question, hoping it will go by unnoticed by the mods.
Super Moderator
(*steve*)'s Avatar
      09-02-2010, 12:53 PM
Quote:
I suggest that it probably goes unnoticed by most users too.
I suspect that the links are for google, not real people. I've noticed that google hits this web site really fast, and hits get very highly placed. That makes it a target for the less scrupulous SEO operators.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Re: Little 1:10 audio transformer as HV transformer Martin Riddle Electronic Design 0 09-17-2011 08:23 PM
Re: 3phase induction motor and transformer are working on the same principle of em induction only , in motor alone why rmf is produced why not in transformer? Don Kelly Electrical Engineering 4 04-02-2008 01:48 AM
Re: 3phase induction motor and transformer are working on the same principle of em induction only , in motor alone why rmf is produced why not in transformer? phil-news-nospam@ipal.net Electrical Engineering 0 03-26-2008 02:12 PM
Dzn transformer, short circuit and currents on primary side of transformer. Cubus Electrical Engineering 3 06-22-2007 03:29 AM
Using standard 50/60hz transformer as output transformer powerampfreak Electronic Design 26 04-06-2007 09:11 PM
