Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electronic Equipment > transformer based DC power supply safer than switching power supply?
Reply
Thread Tools Display Modes
james
Guest
Posts: n/a
      05-31-2009, 05:41 PM
I have a broken table tennis robot (shoots ping pong balls). I found that it
has two DC power supply (12V x 2), and one of them failed.
The easiest solution is to use a spare computer PC power supply to replace
the defective one.
My only concern is this. The power supply in the robot is transformer based.
A PC power supply is transformer-less switching circuit, which means no A/C
isolation from the mains. Would this make the resulting device less safe?
Baron
Guest
Posts: n/a
      05-31-2009, 06:02 PM
> that it has two DC power supply (12V x 2), and one of them failed.
> replace the defective one.
> based. A PC power supply is transformer-less switching circuit, which
> means no A/C isolation from the mains. Would this make the resulting
> device less safe?
A PC power supply provides Isolation from the incoming AC mains !
Whatever gave you the idea it didn't ?
Best Regards:
Baron.
PeterD
Guest
Posts: n/a
      05-31-2009, 08:37 PM
>the defective one.
If you know so little about mains isolation and SMPS design, I'd
suggest keeping to ping-pong, and let someone else fix the unit. A
SMPS is fully isolated.
Well, were someone who knows what they are doing to fix it, it would
be just as safe.
krw
Guest
Posts: n/a
      05-31-2009, 08:49 PM
On Sun, 31 May 2009 16:18:27 -0400, "Michael A. Terrell"
>> > device less safe?
> The PC power supply case & common are connected to ground, and can
>short out other power supplies.
True, but the other supplies had better not have their cases hooked to
anything other than ground.
Mat Nieuwenhoven
Guest
Posts: n/a
      06-01-2009, 07:39 AM
>the defective one.
Just a thought: if you replace the transformer(s) with a much lighter
switching supply, doesn't the machine get too light so it becomes unstable?
May be it depends on the transformer weight for inertia.
Mat Nieuwenhoven
Eeyore
Guest
Posts: n/a
      06-01-2009, 11:06 AM
> the defective one.
Wrong ! It is not rated at a suitable power.
Graham
due to the hugely increased level of spam please make the obvious adjustment to
my email address
Eeyore
Guest
Posts: n/a
      06-01-2009, 11:07 AM
Well said Sir.
my email address
Eeyore
Guest
Posts: n/a
      06-01-2009, 11:08 AM
> >the defective one.
Uh ?
Graham
my email address
PeterD
Guest
Posts: n/a
      06-01-2009, 01:30 PM
On Mon, 01 Jun 2009 12:08:31 +0100, Eeyore
>> >the defective one.
>Uh ?
>Graham
Every action creates an equal and opposite reaction. So it fires a
ping-pong ball forward, and as a result the opposite energy is
directed in the other (rearward) direction.
With an SMPS there is no question that that will launch the machine
into the next room with sufficient force to cause personal injury or
even death to anyone unlucky enough to be in the way.
The resulting ripping of the power cord from the machine will then
allow live wires to arc on the floor, igniting the carpet and causing
a fire.
The resulting fire will destroy the house, and then spread to the next
house.
The ambulance which was called for the person struck by the machine
will be involved in an accident, blocking the route for the fire
trucks.
The fire will spread to near by houses, and continue to spread
unabated until the entire city is consumed.
The authorities will assume (incorrectly, perhaps) that the
destruction of the city was cause by terrorism and will call for war
against the guilty parties.
There will be no survivors...
Mat Nieuwenhoven
Guest
Posts: n/a
      06-02-2009, 05:27 PM
>>the defective one.
On second thought, this might be a desirable side-effect if it makes the
machine just slightly unstable: the paths of the pingpong balls become more
unpredictable, enhancing the training experience :-)
Mat Nieuwenhoven
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Questions on op-amp based adjustable power supply keebler65@mn.rr.com Electronic Design 12 09-22-2006 07:50 PM
Switching power supply indep Electronic Repair 1 03-23-2006 12:13 AM
Auto switching power supply between USB power and external supply ganeshokade@gmail.com Electronic Design 3 04-30-2005 01:56 PM
Re: X-Box power surge - blew out switching power supply rkpatt758@my-deja.com Electronic Repair 0 12-25-2004 01:33 PM
switching power supply larry Electronic Design 0 08-10-2004 03:23 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93
