So I am on a continued path to find the best way to use this new cheap high resolution printer.
The previous tests show that the printer produces a very high resolution output and it is possible to transfer the toner.
The problems are:
1) getting it to stick
2) getting the rest of the copper exposed to etchant
3) reducing etching through the toner.
About three weeks ago I performed a number of other tests using a toner release paper and two different types of film.
Firstly a close-up of the image as it is printed. These are not the greatest, but will give you some idea of the resolution.
The first images are printed on toner release paper. The images are good enough in places that you can see the surface texture of the paper. Note that you do not see fibres. Also note that there are some areas where excess toner appears to have been deposited.
The images are quite mottled, and the toner layer is clearly very thin. It looks very much like there will be significant etching through the toner.
Next are the images printed on the blue film. On a normal laser printer you get a nice crisp black image. But not using the 205b. The images look pretty bad, very little toner appears to have adhered to the film. Also note that there appears to be much more toner in places that it isn't supposed to be.
Fine lines are not affected so much, but the thick lines here are only 0.4mm in width.
Here is the first toner transfer (still a little wet). As you can see the paper has come away completely, but that copper can be seen through the toner.
What you don't see is how the toner has come unstuck near the edges of the board.
Sorry about the fuzzy image. The fine line here represents the edge of my board, so these problems are outside the board area, but extend quite some distance from the edge of the board (up to 8mm or so).
This lack of adhesion may be due to adhesion, lack of cleanliness, or too low a temperature when transferring. Later investigation reveals that surface preparation is the major contributing factor (but I don't want to spoil the surprise just yet)
The blue film is an absolute failure. Note that the thinner lines are relatively unaffected, and the thicker lines have both more excess toner around them as well as voids within them. This is going to be an unhappy result, but I'm going to do it anyway.
Note that the blue film performs very well using other printers so I suspect the problem is something to do with the Xerox toner.
Here is another view of a board after the release paper had been peeled back (it actually lifts off). Note the adhesion issues around the edge of the board. This is not a particularly bad example!
This board was cleaned with steel wool, then washed in laundry detergent (good at cutting through grease) before being rinsed and dried using isopropyl alcohol.
The next step was to use the green film to seal some of the transferred toner. In contrast with the blue film, the green film is not printed to, it is placed over the toner image and the film is fused to the toner.
Note that there are some areas where the green film has not adhered, and that the green film tends to remain in small voids like dome of the very narrow gaps between tracks. Unfortunately because of the lack of adhesion of the toner to the board, removing this using tape risked removing the toner as well
Here is the green film that was removed
You can see some of the small pieces of toner removed and where the green film has incorrectly come away or remained on the board. The large pieces of toner that you can see are from another board, they are the large pieces of toner from around the edge of the board.
Some areas of toner transfer are particularly bad. The following area looks to have been affected by the paper moving slightly. It's not typical, but illustrates the requirement to keep the paper and board from moving relative to one another.
This problem is probably compounded by the fact that the board needs to go through the laminator at least twice before it adheres well enough not to very easily pull away. This suggests that a slower transport speed or higher roller temperatures (perhaps better controlled roller temperatures) would be an advantage.
Here is a wider angle view of the board. It's pretty clear that something happened at the right side of this board (which happens to be the "back" -- i.e. last to go through the laminator -- of the board as it passed through the rollers). The edges look pretty good on this board, but don't be fooled, huge chunks still fell off.
Those problems are in contrast to areas of the board where the paper did not shift.
The pads in the middle are for a BGA device that is 2mm x 2.5mm in size (It's an LM2795TLX if you're interested). You can see some copper through the toner, but the toner image looks sharp.
The etching was done with warm Ferric Chloride (around 40C) in a bubble tank.
Here are two boards that had a simple toner transfer image. They look pretty good.
Until you remove the toner...
Here is where you can see the extent of the problems with etching through the toner.
Here are two "film" boards. There are significant problems with both and for once, perhaps, the lack of focus is a blessing.
Once you remove the film and toner, the results are as poor as you might have expected. The press-n-peel blue film looks pretty nasty. As mentioned above, this is a toner issue, not a problem with the film.
The green film appears much, much better at first glance.
However, the areas where the green film remained on the board exhibit some significant under-etching (although not as bad as you might have expected having seen the image before it was etched)
Something that's not obvious here is how tricky it can be to get the green film applied without dust or creases. It's VERY thin and sticks to itself via static electricity -- which also attracts dust.
But there is no doubt that where the image is good, it is very very good.
The problems with creases can be seen here. A significant number of voids (possibly caused by dust are also visible.
Surface Preparation.
Several tests were done with each method (I haven't shown them all). One perplexing problem is that tests done on dirty boards always seemed to work better than the most highly cleaned boards. Whilst the former may have areas that totally failed (due to greasy fingerprints usually), they worked better in the "good areas".
This lead me to consider what I was doing when I prepared the surface.
One quick test was to dip the board in the ferric chloride very briefly (until the board turned salmon pink) hoping that the start of etching would produce very small surface pitting that the toner could stick to.
The first board turned black and mucky after being left to dry so I tried to clean off the muck. This muck proved to be very hard to remove. However, it made me think about boards that had worked -- they also had a darker colour.
I dunked the board in the etchant again and then left it in the sun to dry, determined to leave the board otherwise uncleaned. At that time the sun came out and the board darkened very rapidly -- clearly the etchant had made the board photo-sensitive (possibly due to copper chloride?) and the light was causing a reaction that produced a darker chemical (perhaps copper oxide?).
Here is what it looked like after only a few minutes
This looks pretty shocking, but the results after etching a toner only image look much better.
Note that the right end of the board was under kapton tape and did not get hot enough to melt the toner.
But also notice the edges of the board. The adhesion of the toner to the board is much better. In other areas of the board there was some failure to adhere, but it was limited to 2 or 3 mm rather than the 8 (ish) that was seen earlier.
The copper has clearly been etched through the toner, and there is some evidence that the toner has smudged a little.
The next tests will be to try the oxidised board with green film over the top. The better adhesion of the toner should allow more of the excess film to be removed.
This also suggests that some of the earlier techniques using plain paper could be revisited, however the time it takes to remove the paper backing tends to suggest that toner release paper plus the green film may be the way to go.
